header clearance/oil pan
Old Oct 19, 2015 | 09:59 AM
usuallybowtie's Avatar
usuallybowtie
Noticed that one tube of my driver's side header is very close to the oil pan flange/rail. Like less than a 32nd of an inch. Will this destroy the cork gasket and cause problems or is the thickness of the block wall and gasket surface there enough to act as sufficient heat sink?
Heddman headers on '75 f100 4x4 with 360.
Old Oct 19, 2015 | 10:00 AM
usuallybowtie
I already dented it a little for more clearance.
Old Oct 20, 2015 | 10:35 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
With the engine fan and just normal air flow when driving, I don't think you have much to worry about - I remember my headers were pretty close at the same point, and never had an issue with heat and that's with some hard 4x4 action.
usuallybowtie
Oct 19, 2015 12:39 PM
jawilla
Apr 6, 2013 12:54 PM
Boz Turner
Feb 8, 2007 06:28 AM
79driver
Jan 10, 2007 10:42 AM
