Bronco II Ford Bronco II
Cold idle problem
Old Jul 1, 2004 | 10:30 AM
Dave53219's Avatar
Dave53219
Cold idle problem
Hi, I have an 87 bronco II,2.9, 4w, 5 speed manual that starts great but wants to die for the first minute or so. Any suggestions? Thanks
Old Jul 1, 2004 | 12:09 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I would start by checking the fuel pressure, pulling the codes and any basic maintainence, theres infomation about this in the tech info thread.
Old Jul 1, 2004 | 02:09 PM
mrshorty's Avatar
mrshorty
I've seen a TSB that describes this problem. If Ken00's suggestions don't yield anything helpful, clean the IAC valve, throttle body, and the upper intake manifold.
Old Jul 3, 2004 | 09:58 PM
89bII4x2's Avatar
89bII4x2
Mine does the same thing, i'v had the iac off and cleaned it, put almost a whole can of intake cleaner through the throttle body, changed the plugs, cap, rotor, wires, coil, fuel filter, and even the tps. (not all because of this problem). I'm thinking now It's a vacum leak i cant find or either the fuel pump or the fuel pressure regulator.
Old Jul 4, 2004 | 06:13 PM
Ken00's Avatar
Ken00
The fuel pump is in the tank on a 89, regulator is on the drivers side fuel rail, it has a vacuum and two fuel lines going to it.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
