Aerostar Ford Aerostar
"ALT" Light on ?
Old Jul 1, 2004 | 09:21 AM
Leader's Avatar
Leader
Question "ALT" Light on ?
I have a '94 Aerostar and the "ALT" light on the dash just came on yesterday. Today as I was getting ready to pull & replace the alternator, I checked it before I pulled it. No load, everything off Bat shows 12.6 volts.
Running Bat shows 14.6 volts.
Looks like the alt is fine to me.
What could be causeing the "ALT" light to be on all the time ?
10 yrs. old & 180,000+ miles on the Aerostar doesn't make me want to drive it very far with the light telling me "something" is wrong.
Old Jul 1, 2004 | 10:05 AM
M.Herrington's Avatar
M.Herrington
you could have a loose battery cable, or a loose connection at the alternator
Old Jul 4, 2004 | 10:31 AM
fordnut71's Avatar
fordnut71
well i got a friend who owns a alt shop an he told me they have seen this all the time with a 3 g alt an its the single wire is got dirt an corrosion on it . so just clean it up an a bit of electrice grease an it should be ok . if the alt light comes on an your volts drop then u have a problem
Old Jul 4, 2004 | 11:48 AM
Leader's Avatar
Leader
THANK YOU THANK YOU THANK YOU !!!!!!!!!!!!!!!!!!!!
That was it. Clip on plug got broke when I last changed the alt & was the problem.
brokeasajoke
26
Dec 20, 2016 04:38 PM
navycob
Modular V8 (4.6L, 5.4L)
Oct 5, 2015 11:14 AM
rwtdct
Aug 7, 2012 08:05 PM
remadl700
Modular V10 (6.8l)
Aug 17, 2011 06:20 PM
thebeast88
New Member Introductions
Jan 14, 2010 08:19 PM
