'96 Check Engine Light & problems
Old Sep 4, 2002 | 01:18 PM
me2's Avatar
me2
'96 XLT 4.0L, 145,000 miles
Check engine light on; AutoZone got codes of 401 & 420. Yesterday, truck very hard to start cold w/o giving gas and would not idle. (like no choke at all) Ran rough & would die w/o foot on gas. Drove 20 miles to work in this condition (highway), then same thing after work when started. After driving in town and 3 stops at auto stores, I accelerated hard when taking off out of a parking lot. Truck started running fine then, idled for about 10 mins during a wash, then drove fine 20 miles home. Started/ran fine today.
Any idea where to start?? Figure a sensor or something is going out, but what?
Thanks-
Old Sep 22, 2002 | 03:54 PM
laurent5's Avatar
laurent5
I am having the same problem. I have a 96 exploder 116000 miles. I have a code 0401 and I have changed the EGR, and the Control solonid, and gone over the entire EGR circuit. The car seems to satrt ok but I have been having this check engine code for months now.
Old Oct 1, 2002 | 09:49 PM
slappy78's Avatar
slappy78
i have a 96 ranger 4 liter, same problem with the check engine light and computer says egr valve.....going to pull that bulb out some day!
Old Oct 3, 2002 | 08:22 AM
SplashMan's Avatar
SplashMan
Try cleaning your MAF and IAC with 02 safe carb cleaner. Make sure you DO NOT direct the stream from the carb cleaner right at the MAF filiments... they are similer to light bulb filaments and will break. Just give them a good coating and then let the MAF dry. Disconnect your battery while doing this and then reconnect it after you are finished. Take a 30 min drive at varying speeds to reset your ECU. Good luck.
Old Oct 3, 2002 | 09:24 AM
adbradley's Avatar
adbradley
straight6fl
May 2, 2020 03:27 PM
1995fatherof4
Jan 3, 2016 10:01 PM
CmdrZod
Dec 22, 2015 07:10 PM
jtsantes
2004 - 2008 F150
Jun 25, 2012 07:46 PM
ColonyPark
4 Cylinder Engines
24
Aug 1, 2006 08:55 PM
