4 speed to C6 conversion
Old Jul 13, 2004 | 12:54 AM
  #31
76  F250 4X4's Avatar
76 F250 4X4
I'm very happy with my C6. I don't think any C6
has overdrive as that would require a 4th gear. I think you'll have to get a newer tranny and I don't know much about them or if any of them will bolt to an FE engine. Ken Collins (kennethl6@prodigy.net) would know.
Old Jul 13, 2004 | 03:58 AM
  #32
Torque1st's Avatar
Torque1st
Posting Legend
You can get bolt on gear splitter or overdrive units for a C6. They cost big bucks tho.
Old Jul 13, 2004 | 08:36 AM
  #33
Crewcab1976's Avatar
Crewcab1976
I don't think there are any automatic transmission out there that will bolt to an FE engine - I checked on the ford truck automatics and the newer models do not fit. Which leaves a fella with three choices - 1. stay with what you have and try to find the right gear ratio for your needs, 2. convert your truck to a 429/460 motor where OD autos are available (I like my 390), 3. or go with the gear vendor types units (as stated, big $). I chose #1 because I think I can get what I need without making major changes or spending major $. I know there are manuals out there that will work, Clark 5 speed, but I could not find one and it would still leave me with all that shifting.
Old Jul 13, 2004 | 09:41 AM
  #34
Crewcab1976
I apologize for "padding" - It will not happen again.
Old Jul 13, 2004 | 10:01 AM
  #35
76 F250 4X4
Gear ratios & strength C6 vs. AOD or E4OD?
Are the OD trannys as strong as a C6 and what are the gear ratios of each?
Old Jul 13, 2004 | 10:14 AM
  #36
Crewcab1976
I quit investigating when I found that it would mean an engine conversion. I like the gear vendor option but last I checked it was about $2400. It would take a lot of miles to pay for itself.
Old Jul 13, 2004 | 08:59 PM
  #37
Torque1st's Avatar
Torque1st
Posting Legend
The AOD is based on the weaker C4 or C5 transmission, I can't remember which. The E4OD seems to be similar in design to the C6 and some parts interchange. My C6 wide ratio gearset came from an E4OD. Gear vendor units are available on eBay occasionally. I paid less than $500 for mine.
hillbillyk
Large Truck
Nov 6, 2014 10:30 PM
insufishentfunds
Feb 22, 2014 02:31 AM
Deerhunter76
25
Dec 24, 2013 07:44 PM
94150
38
Jun 19, 2013 09:35 PM
