390 Stroker kit
Old Nov 27, 2013 | 10:02 AM
Deerhunter76's Avatar
Deerhunter76
390 Stroker kit
I am new to 4x4s, at least rebuilding them. I just aquired a 1976 F-250 Highboy with a 390. I was reading about the Stroker kit with a few mods and it said I could get 500 horsepower and 500 ft/lbs of torque. Will this work in a truck? the article was speaking of racing.
Old Nov 27, 2013 | 12:27 PM
Blue and White's Avatar
Blue and White
I understand 390 stroker kits work very well. How you build it and resulting power rating depend on usage and budget.
A 500 HP version would have a big high overlap camshaft. Lots of high RPM power but not so good at lower RPM. Plus a lopey idle and poor fuel consumption. For 4x4 use a build with milder cam more low/mid range torque is more suitable. Built for 400' ish HP would make a better engine I think unless you are running the 1/4 mile. You still can get the big torque number just at lower RPM.
Old Nov 27, 2013 | 02:01 PM
AK FORD GUY's Avatar
AK FORD GUY
I personally think that anything in the 300-400HP range would do just fine. Just make sure it is built for low end torque, that is the more notable aspect for a 4x4 truck.
Have fun and keep us posted.
Old Nov 27, 2013 | 03:38 PM
turbohunter's Avatar
turbohunter
Just did one.
408 hp
500 ft lbs
On D2 heads and a Comp XR 270
Old Nov 27, 2013 | 09:33 PM
Deerhunter76
Thanks
Thanks for the info. I am looking for the low end torque. Turbohunter, would you mind sending the mods that you used?
Old Nov 27, 2013 | 10:08 PM
turbohunter
Exactly what I was looking for.
I didn't care about hp. The fact that I got it was icing on the cake.
Started with a 105 block with webbing.
4.125 bore
4.125 Scat crank kit
6.8 rods
Custom Ross pistons (can give you specs)
Stock D2 heads with some cleanup work and a nice valve job.
XR270HR Comp roller cam
Comp roller lifters
PRW roller rockers with Manton adjusters and Manton push rods
Performer intake port matched to heads
700 Holley dp
Old Nov 27, 2013 | 11:07 PM
1984F150SB's Avatar
1984F150SB
Originally Posted by turbohunter
Just did one.
408 hp
500 ft lbs
Just curious have you figured out what kind of MPG's you're getting with this set up? I know when I was running Jeeps guys that stroked the 4.0's got considerably better gas mileage strictly because the extra power let the engine run at lower RPM's at speed. I ask because on the long list is a similar build of my 360/390 ( still haven't dug into yet I'll get to it one of these days) but I just tripled the 4 mpg I was getting when the I bought the truck and not sure I could live with much less the then the 10- 12 I'm getting now.
Old Nov 27, 2013 | 11:30 PM
smokenchoken's Avatar
smokenchoken
just fyi you probably only have a 360 in your highboy the if i remember right the 390 wasn't even an option in the highboy so unless in all these years someone has pulled one from something else and put it in your truck chances are its just a stock 360
Old Nov 27, 2013 | 11:38 PM
85e150's Avatar
85e150
All the better if it is a 360. Not enough power to have worn itself out, so they say. Block is the same, and it will take the same stroker set up, so the OP will get the same results either way.
Good luck with it.
Old Nov 27, 2013 | 11:48 PM
smokenchoken
true and there is nothing really wrong with a 360 they are just a little weaker and get crappier gas mileage but can live through about anything due to their underpowered nature they can't really hurt themselves unless its driver stupidity and like you said all stock 360s still have a 4.05 bore same as a 390 so stroking is just the same but to the op not all blocks can be safely bored past a certain point and your machinist is the only one who can check to see just how much you can bore it with no issues and if the machinist doesn't have at least 2 other FE's in his shop find one that does since they are a different breed then the rest of the ford motors.... and despite what a lot of people think sleeving isn't all that bad sometimes that is the only way to safely get the size of bore you want/need..... rant over
Old Nov 28, 2013 | 09:42 AM
turbohunter
Am hoping for 16 but really don't care. Getting 12 to 14 with the 360.
I agree, they do what they are supposed to do. If you want an engine to run forever, a 360 fits the bill.
Old Nov 28, 2013 | 10:11 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Yeah, the 360 will run for a long time. What usually does them in is too many valves burned (low compression) or too many oil leaks, dumping oil as fast as you can pour it in.......
Old Nov 28, 2013 | 10:28 AM
turbohunter
Your post made me chuckle.
I certainly have some oil spots in my driveway.
Old Nov 28, 2013 | 11:22 AM
Rogue_Wulff
Yeah, the 390 "marks it's spot" pretty well too. Rear of intake leaks. For now, it gets parked on the street, where it's the city's mess to clean up.
I still haven't got around to installing the Performer intake I bought 2 years ago. Might just pull the engine and freshen it up/reseal it completely, since it was built over 22 years ago..........
Old Nov 28, 2013 | 11:32 AM
turbohunter
You know on the subject of the Performer intake.
I was quite surprised that it supported 411 hp.
They get a lot of poopooing in the forums but it did more than what it was supposed to.
Of course I did port match it to the heads BUT did not take out the runner profile.
As far as I'm concerned it's a hell of a good truck manifold.
