4 speed to C6 conversion
Old Jul 1, 2004 | 10:19 PM
olfordsnstone's Avatar
olfordsnstone
I had to move the cross member to line up the rear trannie mount when converting from a c-6 to a 4 speed NP 435. I suppose you would need to move your cross member as well but in the opposite direction.
Old Jul 2, 2004 | 02:28 AM
Crewcab1976's Avatar
Crewcab1976
Idahocrewcab and oldfordsnstone,
Thanks for the info - the cross member and mounting of the tranny were one of my concerns. Sounds like I can move the one I have to the correct position and bolt it in place.
I know there is a certain amount of power and drive train efficiency loss with an automatic transmission. I accept that as part of the convenience of not having to shift constantly.
It doesn't sound like there are any major obstacles to this conversion. Thanks for the input.
Old Jul 3, 2004 | 06:18 PM
Sgt Wonderful's Avatar
Sgt Wonderful
Have you considered the rear end gear ratio difference, when going form a manual to an automatic? I made the swap from a 3 speed to a c-6 in my 79 300 six and didn't change the rear end. The MPG ended up at about 11.67. I had to add a rear tranny support for the c-6. it bolted in. All works fine except for ther MPG.
Old Jul 4, 2004 | 06:15 PM
lastchance's Avatar
lastchance
Now you have me wondering...would a truck that came from the factory with a manual transmission normally have lower or higher rear gearing than an automatic transmission?I'm still working on the same swap myself in my 79 F250 4x4. Just got the 300 fired up today...runs like a clock!! FTE user HillbillyK, gotta thank you for that engine!
Old Jul 4, 2004 | 10:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
A std tranny vehicle would normally have higher numeric gearing. The torque amplification with an automatic offsets the difference.
Old Jul 7, 2004 | 12:27 AM
Cheapevil's Avatar
Cheapevil
I have a 74 crew 4x4 stock motor was a 360 has been swapped out for a 390 tranny is a C6 with unmarried(divorced) transfer, and I gotta say I love driving it it wheels great and is nice to drive in town. My only complaint with it is the turning radius sucks it is like driving a duce-n-half all over again with out the shaved head and BDU. Good luck on your swap and keep wheeling.
Old Jul 7, 2004 | 09:21 AM
Sgt Wonderful
Torq: what does that mean, off set the difference, what difference?
Old Jul 7, 2004 | 09:23 AM
Sgt Wonderful
Lastchance: keep me posted on your reand end swap.
Old Jul 7, 2004 | 11:31 AM
Crewcab1976
I'll post after I have made the change to let you know how it goes.
The conversation around the gearing is a concern for me, but I will be going to higher gears next. I currently have 4:56's and will go to either 4:10's or 3:73's - I need to save up some money first.
Cheapevil; I can relate to your steering complaint. I have to carefully plan my entrance and exit to every parking lot. After I change my gearing, I am going to convert to the 1977 1/2 to 1979 steering gear. There is an article on this web site in the tech section that outlines the conversion. Also, if you go to Ebay and look under auto parts: steering and suspension: and search for "ford conversion" there is a guy selling all the parts needed to make the conversion. It is a lot of money, but well worth it - I had a standard cab 77 1/2 F250 that steered and turned more like a modern truck than the set up we have.
Old Jul 7, 2004 | 03:13 PM
Torque1st's Avatar
Torque1st
Posting Legend
An automatic usually has a lower numeric ratio rear end than the std transmission because of the torque amplification possible in the torque converter. An automatic equiped vehicle will usually have a higher tow rating than a std also for the same reason. A load that would stall out the engine with a std transmission will slip the torque converter and keep pulling with an automatic. An automatic also slips in the torque converter when cruising down the road and the lower numeric ratio in the diff helps compensate for that also.
I will be running a high torque 400 in my truck with a custom wide ratio C6, towing converter, an overdrive, a 3.07 ratio Dana 61, and 265/75R16 tires.
Old Jul 7, 2004 | 03:49 PM
lastchance's Avatar
lastchance
Don't mind me, this is starting to get over my head a little...so if I leave my truck geared as it was with the 4 speed it will pull better? With the 4 speed 1'st gear was usually a little slow to pull out, and starting out in second I had to ride the clutch a little to get her going...all while pulling onto a busy highway at a blind hill with a half ton or more hay bale teetering on the on the bed! I'm not worried about speed or economy so much, the truck usually never gets more than 10 miles from the house, and usually never gets over 45 MPH.
Old Jul 9, 2004 | 11:15 PM
76  F250 4X4's Avatar
76 F250 4X4
Just completed '76, 4X4, F250, 360, NP435 to C6 &
I can tell you exactly everything you need to know. Mine works great but it wasn't a dance in the park. I knew I'd need rotator-cuff surgery if I left the 4-speed in.
Old Jul 12, 2004 | 04:42 PM
  #28
Crewcab1976
rheacox,
I am a new member to this web and am not able to send an e-mail directly to you. I would greatly appreciate your input,advice and answers.
I will be ordering my transmission this week from a local shop but probably won't start the conversion for a couple weeks. My truck already has a steering column for an auto without the indicators and lever - so it might have had a auto at some point in its past. At any rate, please feel free to contact me through this forum - or I will go out and post some more comments to surpass the required 15 and send an e-mail direct to you.
Thanks for the offer
Old Jul 12, 2004 | 05:23 PM
  #29
Sgt Wonderful
rheacox, If I were to do it again, I would look for a C-6 with over drive. IMHO.
Old Jul 12, 2004 | 06:09 PM
  #30
Crewcab1976
Sgt. Wonderful,
I have looked and asked several different sources to try to find an overdrive auto that will bolt to a 390 with no luck. Do you know of a way to get it done? C-6 with overdrive?
