95 ford explorer od light started flashing
Old Oct 16, 2002 | 10:57 AM
lori_pelzel's Avatar
lori_pelzel
Post 95 ford explorer od light started flashing
Lori Pelzel My od light just started flashing and when i depress the button on the gearshift does nothing still flashes. whats going on??Could it just be the switch???
Old Oct 16, 2002 | 07:25 PM
fordfool2's Avatar
fordfool2
I had the same problem on my 95 EB.
I also noticed that the engine RPMs were jumping around a few hundred when the O/D started to flash.
I took it to the dealer and they found the the Throttle Position Sensor (TPS) was bad. The sensor fails in a way that simulates intermittent full throttle to the transmission. This was causing the torque converter to unlock/lock repeatedly.
The sensor is $50 and it is aboslutely the simplest component to replace. It is right on top of the engine and one of the first things you see when you open the hood. There is a test procedure for the TPS if you are unsure.
Old Oct 16, 2002 | 08:15 PM
CNTHOR's Avatar
CNTHOR
The O/D light flashing means that your eec-iv computer has registered a transmission related error. This error code is stored in the computer and can be read out by using a code reader or a simple jumper wire and counting flashes on the check engine lamp (MAL).
If your transmission feels ok and you dont remember anything wierd happening, then you can "reset" the computer by pulling the + terminal off your battery for about 5 minutes. This will also reset the cars driving characteristics however.
You can also reset the computer using a jumper wire under the hood.
If you are interested in using the jumper wire to read the codes. then E-Mail me at carlt@tec-system.com and I will send you detailed instructions.
"I hope you have been having you tranny fluid flushed regularly"
Old Oct 17, 2002 | 12:24 AM
lori_pelzel
Yes. It's 'been flushed. I have a code reader and the new code it gave me today after the od light was 513. Which I believe is somethhing to do with the pcm. Hopefully it just needs reset. Thanks for your help..Lori Pelzel
Old Oct 17, 2002 | 01:50 AM
rgiles's Avatar
rgiles
lori_pelzel
Jan 29, 2003 06:59 AM
lori_pelzel
Oct 23, 2002 07:14 PM
lori_pelzel
Oct 17, 2002 12:24 AM
lori_pelzel
Jun 1, 2002 02:40 PM
lori_pelzel
May 31, 2002 06:22 PM
