What is it.
Old Jun 28, 2004 | 10:13 PM
dslpower's Avatar
dslpower
Question What is it.
I recently purchased a 93 7.3 IDI no turbo, 4X4, F250 supercab. It has some sort of electricial plug under the steering column with a plug in it with prongs on it. It looks like the thing you unplug on newer fords that will prevent the truck from running. the truck runs the same with or without the plug. Like a bat outta hell. there are 4 wires and two are cut off. the other two dissappear into the dash and . some wires run to a box with a circuit board in it laying loose behind the glove box. It has a small red light in the dash that is cut and there was a switch or button under the steering wheel. The feul pump must be turned up because it has some toxic fumes at idle. I getting around 16MPH all the time. Any ideas. I can send pics.
dmcamacho
Mar 5, 2022 02:09 AM
cdrich07
Sep 16, 2013 01:17 PM
90pioneer
29
Sep 6, 2012 10:30 PM
loyal
May 22, 2009 12:48 AM
atomicjoe23
46
Feb 27, 2009 07:58 PM
