I'm not sure of the pressure going through those lines, but if it was me, I'd just cut out the leaking section, and replace it with some rubber hose and hold it in place with two hose clamps. It works on your fuel pump, power steering pump, and whatnot, so I'd think it'd do the job for this too.
Of course, I'd get some fancy silicone hose like what I have on my oil breather cap, but that's just me.
the "fancy" one i have on my oil breather, is an old garden hose hahaha
and i'll look into the hose thing, i don't know about the pressure either, so yeah. lets see what others have to say
I'll do a bit of research, if I find anything out I'll let you know. I read somewhere that the power steering system has over 1,000 psi on the high pressure side (I don't know for sure, I could be WAY off), so the low side probably still has a decent bit of pressure on it. I'd think if it was the right size, PS return-line hose would work fine.
Reason: COULD, not WOULD....lol
It is very common to use fuel hose to patch the lines. I would put two hose clamps on each end though.
I have driven many trucks this way with no issues.
It isn't the write way, but is a common cheap practice.
that is how i would do it.
Those lines do not have any more than the radiator does.
Though I can say this, around 2003 or 2004 my dad and I replaced a small section of metal fuel line between the carb and the fuel pump on my '81 with a section of rubber hose, and it wasn't til a few months ago that I noticed it leaking just a little bit. So I doubt durability will be a concern, unless you get a type of hose that isn't rated for the heat and stuff. That PDF I linked to says the max temp of this trans is 250F, continuous 220F.
If you want a permanent easy repair, go to the parts store and get some universal steel fuel line the correct size, and also buy some brass couplers with the ferrules in them. Take the line loose on the one end, and install the new line, then cut it to go past the bad spot and use the brass couple to connect them together.
Fuel line will work also, the pressure is not great enough to overcome regular line and a hose clamp.
No, it is leaking from age and neglect.
But it will hurt the tranny over time driving with it in there.
It should be fine, I have done the same mess up.
Just change it to the right stuff.
