another 0171, 0174 problem
Old Jul 1, 2004 | 07:56 AM
pawpaw's Avatar
pawpaw
Cscottr, on the computer relearning slowness, read through the following thread, it may offer some relief, unless what you have wrong is so out of tolerance the computer just can't compensante for it. Scroll down about 5 times, to Dave 257's post on drive cycles.
https://www.ford-trucks.com/forums/s...5&highlight=co...
You can also use a piece of hose, one end to your ear, the other end to probe around the suspected part, to listen for the "hiss" of a vacuum leak, then squirt the area as suggeted, to confirm the problem.
Old Jul 1, 2004 | 08:11 AM
Rockledge's Avatar
Rockledge
On your '99 OBD-II system with heated O2 sensors, the system goes into closed loop approximately 30 seconds after cold start. It is not dependant upon engine temperature.
You should indeed track down a FP tester and check it yourself. Even still, a clogged fuel filter can cause driveability issues while at the same time allowing for a fuel pressure check at idle that falls within specs.
Old Jul 1, 2004 | 08:14 AM
cscottyr's Avatar
cscottyr
Hey pawpaw,
That does explain a couple of things. This vehicle has been much slower to learn when the gas tank was 1/4 or less. Also, since I live in the country - some of the roads have been a little less than ideal. I will also try what you and el conquistador recommended about searching for leaks.
Thanks
Old Jul 1, 2004 | 08:20 AM
cscottyr's Avatar
cscottyr
Hey Rockledge,
Thanks for the o2 info - I guess I was confused with what gm does. They place the o2's in the ckt after a brief warmup but then monitor them for changes for a while after that. If they do not change after some nominal amt of time the Engine sets a code. I do intend on checking the fuel system at first chance also - to see if I can get the pressure after the regulator to change with speed. I'd love to check it under load.
Thanks again!
cscottyr
Old Jul 1, 2004 | 08:27 AM
cscottyr's Avatar
cscottyr
hey pawpaw,
The Post you had me read from dave 257 - said that the evaporative monitor only monitored for the first 30 minutes. What does it do then. Just brainstorming - but that is about the time when the Truck started running very poorly this morning. After about 30 minutes of driving.
Any Ideas?
cscottyr
Old Jul 1, 2004 | 08:40 AM
Rockledge's Avatar
Rockledge
The older EEC-IV (OBD-I) systems without heated 2 sensors do use the ECT (engine temp) to trigger closed loop. So you are not really wrong in your thinking, depending on the application.
Old Jul 1, 2004 | 08:41 AM
Rockledge's Avatar
Rockledge
Arrow Finding And Fixing Vacuum Leaks
Also, FWIW, here is an excerpt from a pretty good write-up on vacuum leaks:
FINDING & FIXING VACUUM LEAKS
Have you ever tried to tune an engine only to find it won’t idle or run right? Or have you ever been confronted with an engine that just doesn’t seem to run right no matter what you’ve done or replaced? You may be dealing with a vacuum leak.
Sometimes a vacuum leak will whistle or hiss and make itself obvious. But oftentimes, it will disguise itself as an ignition or fuel problem that defies diagnosis. Either way, a vacuum leak is bad news because allows "unmetered" air to enter the engine and upset the air/fuel ratio.
So how do you know when a vacuum leak is causing a problem? If the engine is experiencing any of the following symptoms, a vacuum leak is probably responsible:
Too fast an idle speed. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine’s vacuum fittings, hoses and accessories. It’s even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft.
A rough idle or stalling. A performance cam with lots of valve overlap can give an engine a lopping idle, but so can a vacuum leak. A really serious leak can lean the air/fuel mixture out to such an extent that an engine won’t idle at all. An EGR valve that’s stuck open at idle can have the same effect as a vacuum leak. So too can the wrong PCV valve (one that flows too much air for the application), or a loose PCV hose. The rough idle in these cases is caused by "lean misfire." The fuel mixture is too lean to ignite reliably so it often misfires and fails to ignite at all. Lean misfire will show up as elevated hydrocarbon (HC) readings in the exhaust—enough, in fact, to cause a vehicle to fail an emissions test.
Hesitation or misfiring when accelerating. This may be due to a vacuum leak, but it can also be caused by a weak or inoperative accelerator pump in a carburetor, dirty injectors, or even ignition problems such as a cracked coil, worn spark plugs or incorrectly gapped plugs.
An idle mixture that defies adjustment. When setting the idle mixture adjustment screws on a carburetor, the idle speed should start to falter as the adjustment screws are turned in to lean out the mixture. If the screws seem to have little or no effect on idle, you’ve either got a carburetor problem or a vacuum leak.
The important thing to keep in mind about vacuum leaks is that they have the most noticeable effect at idle. At part and full throttle, there’s so much air entering the engine that a little extra air from a vacuum leak has a negligible effect.
WHY VACUUM?
Vacuum exists in the intake manifold as a result of the pumping action of the engine’s pistons and the restriction created by the throttle valve. Were it not for the throttle choking off the flow of air into the engine, there would be little if any vacuum in the intake manifold (like a diesel).
On older carbureted engines, vacuum is needed to pull fuel into the engine. Vacuum siphons fuel through the idle, main metering and power circuits. An engine with a vacuum leak, therefore, will likely be an engine that suffers from the symptoms of lean carburetion such as lean misfire, hesitation, stalling and rough idle. But the same symptoms can also be caused by a clogged catalytic converter or other exhaust restriction, a leaky EGR valve or valve timing problems (all of which reduce intake vacuum).
On most engines, intake vacuum should be steady between 16 and 22 inches. A lower reading usually indicates a vacuum leak, or one of the other problems just mentioned. A reading that gradually drops while the engine is idling almost always points to an exhaust restriction. An oscillating vacuum reading usually indicates a leaky valve or badly worn valve guides.
Fuel injected engines do not require vacuum to siphon fuel into the engine because fuel is sprayed directly into the engine under pressure through the injectors. Even so, vacuum leaks can upset the carefully balanced air/fuel ratio by allowing "unmetered" air to enter the engine. The result is the same kind of driveability symptoms as a vacuum leak on a carbureted engine (lean misfire, hesitation when accelerating, rough idle and possibly even stalling). Common leak points include injector O-rings, intake manifold gaskets, idle air control circuit and the throttle shaft.
Fuel injected engines also rely on intake vacuum to regulate the fuel pressure behind the injectors. Fuel delivery cannot be accurately metered unless a fairly constant pressure differential is maintained. So the fuel pressure regulator diaphragm is connected to a source of intake vacuum. Vacuum working against a spring-loaded diaphragm inside the regulator opens a bypass that shunts fuel back to the tank through a return line. This causes the fuel pressure in the injector rail to rise when engine load increases (and vacuum drops). Thus, the regulator uses vacuum to maintain fuel pressure and the correct air/fuel ratio. A vacuum leak changes the equation by causing a drop in vacuum and a corresponding increase in line pressure.
FINDING LEAKS
One way is to visually inspect all the vacuum hoses and connections. Look for disconnected, loose or cracked hoses, broken fittings, etc. Hey, you might get lucky and find the problem in a few minutes—or you might waste half the day trying to find the mysterious air leak. Vacuum leaks are often the elusive needle in a haystack. And if it isn’t a leaky hose but something else such as a gasket, worn throttle shaft, injector O-rings, etc., you may never find it using this technique.
A faster technique is to get a bottle of propane and attach a length of rubber hose to the gas valve. Open the valve so you have a steady flow of gas. Then hold the hose near suspected leak points while the engine is idling. If there’s a leak, propane will be siphoned in through the leak. The resulting "correction" in the engine’s air/fuel ratio should cause a noticeable change in idle speed and/or smoothness (Note: on engines with computerized idle speed control, disconnect the idle speed control motor first).
Aerosol carburetor cleaner can also be used the same way. Spray the solvent on suspected leak points while the engine is idling. If there’s a leak, the solvent will be drawn into the engine and have the same effect as the propane. The idle speed will suddenly change and smooth out....
PRESSURE TECHNIQUES
Another way to find an elusive vacuum leak is to pressurize the intake manifold with about three lbs. of regulated air. This can be done by attaching a regulator to your shop air hose, then attaching the hose to a vacuum fitting or the PCV valve fitting on the intake manifold, carburetor or throttle body. Do not apply too much pressure or you may create new leaks! With the engine off and air flowing into the manifold, spray soapy water on suspected leaks. If you see bubbles, you’ve found the leak....
You can also use the opposite technique, which is to apply vacuum with a hand-pump to various vacuum hoses and circuits to see if they hold vacuum. But this technique means tracing the entire circuit to see where it ends, and disconnecting and plugging any parts of the circuit that don’t "dead end" against a diaphragm or valve.
FIXES
Okay, now you’ve found the leak. Here’s some suggestions on how to fix it:
Leaky hoses—Replace them. If the end of a hose is loose or cracked, cutting it off and sticking it back on may temporarily eliminate the leak. But if the hose is rotten or age hardened, it needs to be replaced. Shortening hoses may also create additional problems ...Use the correct type of replacement hose (PVC hose or vacuum hose capable of withstanding fuel vapors and vacuum without collapsing). Also, be sure the replacement hose is the same diameter and length as the original.
Carburetor or throttle body base gasket leaks—Try tightening down the carburetor or throttle body mounting bolts. If that doesn’t stop the leak, replace the gasket under the carburetor or throttle body. If there’s a heat insulator or adapter plate under the unit, it may also have to be replaced depending on its condition. While the carburetor or throttle body is off, use a straightedge to check the base for flatness (and the manifold, too). Warped surfaces can prevent a tight seal, so if you find any it calls for resurfacing or component replacement.
Carburetor or throttle body throttle shafts—Wear here can only be repaired by resleeving the throttle shaft, which for all practical purposes means replacing the carburetor or throttle body with a new or remanufactured unit.
Intake manifold gaskets -- Try retorquing the intake manifold bolts, working from the center out in the recommended tightening sequence. If that fails, the intake manifold will have to be removed and the intake gaskets replaced. Sometimes the mating surface of the intake manifold or the heads will not be flat (check both with a straightedge). If warped, the intake manifold and/or heads will have to be resurfaced on a milling machine.
Another problem to watch out for here are heads that have been milled or resurfaced to raise compression. To maintain proper alignment between the manifold and heads, metal also needs to be machined off the bottom of the manifold where it mates with the block, otherwise it will sit to high and the ports and bolt holes won’t align.
EGR valve leaks—If the valve isn’t closing all the way due to carbon deposits on the stem or valve seat, cleaning may be all that’s needed to cure the problem. Otherwise, your customer will need a new EGR valve.
Source
Old Jul 1, 2004 | 08:57 AM
cscottyr's Avatar
cscottyr
Thanks Rockledge,
The article on vacuum leaks was very good - It gives ma something to look at.
cscottyr
Old Jul 1, 2004 | 09:31 PM
pawpaw's Avatar
pawpaw
Cscottyr, I don't rightly know about the evap monitor question, but the 30 minute time frame makes me wonder if perhaps it's something as simple as a bad gas cap.
Next time it acts up after that 30 minute time, immediately loosen the gas cap & let the tank pressure equalize, retighten the cap, restart the engine.
If things smooth out, suspect a bad gas cap.
Old Jul 1, 2004 | 10:16 PM
Rockledge's Avatar
Rockledge
Cscottyr, you might be interested in this, it describes the OBD-II monitoring system on your '99 Ranger:
http://www.motorcraftservice.com/vdi...f/obdsm99a.pdf
Old Jul 1, 2004 | 10:49 PM
racsan's Avatar
racsan
wow doesnt all this high-tech stuff make you want to get back the $800 '71 beater bronco you had for 2 months in the early '90s or is it just me. (bet it's just me) i dont know if it would trow a code but what about fuel octane? mine would ping slightly whil accelerating (4.0/5spd) and i switced from 87 to 89 octane fuel and it helped. all these sensors can be ovewhelming. it took me a while to get rid of the check engine light on the wife's taurus, and i did have a code scanner to help me out. good luck!
Old Jul 2, 2004 | 07:44 AM
cscottyr's Avatar
cscottyr
Hey guys,
Thanks for the posts - I will try the gas cap thing- it sounds like a good idea - (Also - Rockledge thanks very much for the article - I will read that today) however I really want to get a fuel gauge so that I can monitor pressure. Yesterday after I had a fairly difficult trip into work with the truck I was hoping the computer would change the algorithm it was using and let me get home more pleasantly than I arrived. To help the computer come to a differnt control answer I drove it at lunch time and at an afternoon break. Unfortunately my ride home was not pleasant - The truck was very underpowered - There were several hills that I dropped down to under 50 miles an hour - in a 65 - giving her everything I could. When I got home I checked vacuum at idle and it was 18". After that I tried to see if I could find a leak with a little propane. Didn't see or hear any change in RPM.
In the past - after I disconnected the battery - the truck would start to run better after many miles and starts and stops. This time however it doesn't seem to want to get any better, which is a good thing - If it fails hard I think I might be able to find the problem. Last night coming home it really seemed as if I wasn't getting enough fuel to the engine. THe truck seemed to rev ok - but would fail under load. I think a fuel gauge might help me see that. I will look at the fuel cap as a possible problem also although right now I am leaning towards the fuel regulator, pump or filter. - I will aslo read the attached article - other than that I would love to hear what you think.
Thanks
cscottyr
Old Jul 2, 2004 | 08:38 AM
  #28
Rockledge's Avatar
Rockledge
...right now I am leaning towards the fuel regulator, pump or filter...
Me too.
The FP regulator on your '99 is located in the fuel tank, it is part of the pump assembly. It's not on the fuel rail like on earlier Rangers.
The fuel filter is located along the frame rail underneath the driver's side door area, you will probably need a special disconnect tool (most autoparts stores have them) to get if off.
Old Jul 2, 2004 | 08:41 AM
  #29
cscottyr's Avatar
cscottyr
Thanks Rockledge! - Hey Racsan - I know what you mean!
cscottyr
Old Jul 3, 2004 | 09:00 AM
  #30
cscottyr's Avatar
cscottyr
Well - I finally may be geting somewhere - Fuel pressure at the shraeder valve is 56 ponds and holding - It doesn't seem to change with vacuum, speed or anything- just always sits at 56 pounds. I do have one question however, Rockledge you said the regulator is located in the fuel tank - On this 99 ranger there is a silver regulator looking device directly in line before the shraeder valve - If that isn't the regulator what is it? - Thanks
cscottyr
