Aerostar Ford Aerostar
Shake, rattle and roll!
Old Jun 28, 2004 | 11:36 AM
shel 67's Avatar
shel 67
Question Shake, rattle and roll!
I've been experiencing a vibration problem lately. It occurres only when I let off of the accellerator. If I'm on a really smooth highway it gets really bad when I let my foot off of the throttle. As long as there is load on the differential, I have no problem. Could this be a bad u-joint? I went under and checked, but the u-joint seems fine. Any info?
Old Jun 28, 2004 | 04:37 PM
Muffinman's Avatar
Muffinman
Wheel bearings, Tie Rods, Steering Knuckel, Ball Joints, wore out transmission bushing, Motor mounts. It could be any of these or a combination.
Old Jun 28, 2004 | 06:18 PM
jkorreck's Avatar
jkorreck
I have heard, don't want to say this for sure, that that is a symptom of a worn differential? Does the vibration come from the back of the van? And if someone could tell me if the guy that told me this was full of it or not I'd appreciate it.
Old Jun 28, 2004 | 07:04 PM
Racerguy's Avatar
Racerguy
Does it make noise along with the vibration?
A seized U-joint can cause that problem and the only way to find it is to remove the driveshaft so you can pivot the U-joints back and forth.
Yes a worn out diff can cause that too.
Old Jun 28, 2004 | 08:20 PM
shel 67's Avatar
shel 67
It makes a low pitch rumbling sound. Sounds like its comming from about the middle of the van, but I could be wrong. If it is the differential, is there a way to tell?
Old Jul 1, 2004 | 12:33 PM
shel 67's Avatar
shel 67
Thanx Racerguy!! It was a seized rear u-joint. Cost me $12 bucks and now the van rides shake free.
Old Jul 1, 2004 | 01:50 PM
Racerguy's Avatar
Racerguy
Good to hear
Argess
Sep 20, 2012 06:18 PM
slidingdelta
1983 - 2012 Ranger & B-Series
Jun 26, 2010 05:43 PM
lannondiesel
1997 - 2003 F150
Nov 27, 2008 09:56 PM
trucker41
Nov 15, 2006 01:25 PM
LARSON
Aug 20, 1999 08:14 PM
