196lb Tv
Old Jun 28, 2004 | 08:23 AM
Badfish1060's Avatar
Badfish1060
196lb Tv
So I am moving, again, and the age old problem arises again.
How do I move this TV? I am of average build I would say, I cannot even come close to moving this thing even with another dude.
I am trying to come up with some sort of clever way to make it "easy".
Your thoughts?
TIA
Old Jun 28, 2004 | 09:26 AM
fatman66's Avatar
fatman66
see if you can rent or buy on of the dolly things that they use to move big boxes around, it gives you great leverage and has wheels and sometimes straps too. We used to use them to move even crated lawn tractors and washing machines stacked two high when I worked at Sears in the recieving depatment.
Old Jun 28, 2004 | 10:45 AM
jaydez's Avatar
jaydez
join a gym. find someone big enough to help you. make quick friends. then ask them if they wanna come over for a beer and while they are there say, "oh yeah, im moving today, would you mind helping me?"
Old Jun 28, 2004 | 11:51 AM
troxelb's Avatar
troxelb
I have a TV that weighs about that much. Whenever I have to move it I get two other guys. Two guys, one on each end and the third is a backup in case someone slips or something. I don't take many chances on a $1500 TV. It is doable with two guys though. It's awkward but doable.
Edit: I'm average build also. 6'0 about 190 lbs.
Old Jun 28, 2004 | 12:02 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I always dread when my inlaws move. They got a big screen TV that weighs ... Idunno. 300 - 400 pounds? So my father in law gets the idea that this TV goes UPSTAIRS!!! I told him then that it was going to be the last time I helped him move that TV. We had 4 guys moving that thing, with 2 extra guys standing by to pick up any slack.
Old Jun 28, 2004 | 12:23 PM
1970f2504x4's Avatar
1970f2504x4
Perhaps find or rent a hand truck? I would think that should move it pretty easily. Just wrap the thing up good in some blankets to protect it.
Old Jun 28, 2004 | 12:54 PM
fatman66's Avatar
fatman66
hand truck! thats the "dolly thing" I was talking about
Old Jun 28, 2004 | 12:58 PM
emboyd's Avatar
emboyd
Also, when transporting it in a vehicle, rest it on 6 or 7 collapsed corrugated boxes. This'll act as a good cushion for those bumps.
Old Jun 28, 2004 | 01:11 PM
jdmorg's Avatar
jdmorg
some dollies have tracks on the side that faces your legs, this way you can just drag it up the stairs and it doesn't scratch anything and there isnt any of that bouncing up stars and maybe loosing a tv
Old Jun 28, 2004 | 01:19 PM
believer45's Avatar
believer45
When I have something heavy to move I rent a U-Haul appliance dolly. They have a strap to secure the load to the dolly and have track/rollers to go up and down stairs. I have moved a lot of things with them from freezers to slate pool tables (bit of a balancing act) and on and on.
Last one a couple months ago was, if I recall correctly, $9 a day.
Dave / Believer45
Old Jun 28, 2004 | 02:18 PM
sandrat's Avatar
sandrat
Tow Strap, Pickup, Chainsaw. Cut hole in both houses. Attach strap to TV and truck. Use the pedal on the right. ENJOY!
Old Jun 28, 2004 | 06:24 PM
eehoepp's Avatar
eehoepp
Tough it out. Get drunk. Pick it up yourself. Move it. Stop whining. Put some Advil, a glass of water and a heating pad on the night stand before you fall asleep.
Cheers,
Eric
Old Jun 28, 2004 | 07:18 PM
jroehl's Avatar
jroehl
Average build?? And you and another guy can't move it?? Huh?? When I was just out of HS, I was 6'0", 145lbs. (yes, I know, that's very thin), and I went to work for a moving company for a little while. Their approach was that 2 guys could move just about anything--and they stuck to it. Sure, I was tired by the end of the day, but I moved ALOT of heavy stuff, even a few upright pianos with only one other guy.
Fast-forward to now. I've put on 20lbs. (not all of it in the gut, either). I am a painter, and often have to carry 5 gal buckets of paint around. Most of them are 60-65lbs., but some are as heavy as 75lbs. each. Generally, I carry 2 at a time for better balance, so that works out to 120-150lbs. by myself. And, on a dare, I've carried 4 at once on a couple occasions (roughly 250lbs.--125lbs. in each hand).
Get a good grip, lift with your legs, and keep your back straight. Should be no sweat for 2 guys of average build.
Jason
Old Jun 28, 2004 | 11:00 PM
Knobby4604X4's Avatar
Knobby4604X4
I work for a furniture store as a delivery person. We have used only two people on the crew for the past eleven years. We have moved just about anything you can think of that someone might have in a house, either as a tippable side job or just in order to be able to set the new furniture into place. Pianos, sleeper sofas, safes, tanning beds, pool tables, motorcycles, refridgerators, etc... Most people tend to overestimate the weight of an item. Granted, the weight of the tv is probably close to two hundred pounds! My suggestion is that if you can't do as suggested above (lift with legs and grunt it out) then hire two guys that can. Safer for you, money for them.
If the television is a 'floor' cabinet type, you can rent or borrow a set of Roll-or-Carri's. These devices are used to move upright pianos. They slip under each side of the cabinet and are then strapped across the cabinet to each other. A rocker system lifts the whole thing up onto a set of wheels and you can roll it along or use the handles to lift over thresholds or up stairs...
Old Jun 29, 2004 | 07:22 AM
Badfish1060
Jason
You would think so, the couch is actually heavier, but we can move it.
Thing is, this darn TV is only a 26" all the weight is in the mercury in the screen and it has no handles, the thing is impossible.
Average Build = 6'1" 165lbs
my helper about 5'9" 180, my mom is stronger.
