rip off?
Old Jun 27, 2004 | 06:10 PM
jhromy's Avatar
jhromy
rip off?
I am reaching 30,000 miles and one of the services they offer is fuel injector cleaner for 150 bucks, it reads they add a cleaner to clean the injectors, but I do that every 3,000 miles with a 8 dollar bottle of injector cleaner, so should I get this service done? I feel its a rip off for me to give them 150 bucks to put probably a 10 dollar bottle of fuel injector cleaner in there.
Old Jun 27, 2004 | 06:27 PM
87 XLT's Avatar
87 XLT
Dont waste your money, the only thing that will do is make your wallet 150 bucks lighter.
Old Jun 27, 2004 | 07:03 PM
jhromy's Avatar
jhromy
thank you...i wasn't planning on doing it, i was just making sure. I already knew my bottle of cleaner is more than enough.
Old Jun 27, 2004 | 08:10 PM
srercrcr's Avatar
srercrcr
I hear alot of good comments about Chevron Techron cleaner. I use it every 6 months. I drove my old Celica for 180,000 miles using it, and never had an injector problem.
Old Jun 28, 2004 | 12:28 AM
ckrichard's Avatar
ckrichard
The difference between the stuf you buy at 7-11 and the stuf that the dealer uses, is the stuf the dealer uses is directly hooked to the fuel rail. The motor is then started and ran off the injector can, untill all the cleaner is used up and the motor dies. The stuf you buy will cinda help to keep stuf clean, but the dealers stuf will clean the injectors so that there is not one bit of build up on them.
Chris
Old Jun 28, 2004 | 12:39 AM
c96drumm's Avatar
c96drumm
I don't think you need that at 30K miles.
Old Jun 28, 2004 | 01:53 AM
87 XLT's Avatar
87 XLT
Your welcome, I've got 223K on my 87 Ranger & I do the same thing except I use the Amsoil injector cleaner/upper cylinder lube every 6K miles. I've never had an injector problem. I've also never had the 30K service at the dealer, I knew I forgot something. Best thing to do is look at the maintenance section in your owners manual & do the routine maintenance stuff yourself. At 30 K miles there isnt much that actually needs to be done.
Old Jun 28, 2004 | 10:00 AM
Msp541's Avatar
Msp541
30,000 miles you dont really need the injector service to me thats a waste of money, i use the BG PRODUCTS Fuel Injection Cleaner every other oil change and it works fine, something like that will be good as long as you keep up with you fuel filter replacement and correct gas!
Good Luck!
Old Jun 28, 2004 | 10:32 AM
jhromy's Avatar
jhromy
i keep up with everything i want this to last me a long time.
Old Jun 28, 2004 | 01:05 PM
Msp541's Avatar
Msp541
I always change my fuel filter that helps to make sure nothing is getting in the vehicle and i use the Motorcraft one i found out the aftermarket ones aren't is good.
Old Jun 28, 2004 | 02:11 PM
LV Dan's Avatar
LV Dan
Chevron Techroline
I'm a big proponent of Chevron Techroline. I ran the additive through my Porsche at 130,000 miles (after I had just bought it) and it really helped. I now have 230,000 on the engine and the injectors still work great.
If you run Chevron gasoline, they put the Techroline right in the gas but at a much lower rate. Most gas providers run a detergent in their gas, but I found the Chevron Techroline to be the best. After running their gas through five different motors with fuel injectors, I've not had an injector stick on me yet. In fact, one motor, a small turbo charged four banger, seems to get sticking injectors any time more than one tank of gas is run without Chevron Supreme.
So now my Explorer gets mostly Chevron gas (but only regular) and I have not had any injector problems after 76,000 miles.
Old Jun 28, 2004 | 06:03 PM
srercrcr's Avatar
srercrcr
Let's not confuse fuel filters with cleaners. One doesn't substitute for the other.
The filter will trap particles. The cleaner will prevent varnishing etc.
Old Jul 16, 2004 | 01:22 AM
Golfmore's Avatar
Golfmore
BG 44K twice a year.
Zombiemom
Aug 10, 2017 01:48 PM
Herford
Dec 15, 2016 05:54 PM
The Trinity Kid
Aug 27, 2016 10:37 AM
fabsroman
Jul 20, 2016 02:49 AM
Peter Chesky
17
Oct 12, 2015 12:29 AM
