1995 Explorer, Ignition switch?
Old Oct 30, 2002 | 08:16 PM
brett_d's Avatar
brett_d
I'm working on a 1995 Explorer for a friend. Apparently the problem is that when he turns the key on he looses power. This is intermetant and usually happens after sitting throughout the night. He informed me that if he turns the steering wheel or hits the brake he can then get power when he turns the key.
My guess is that it is an ignition switch. I have never worked on these so I wanted some of your opinions. Is the switch the same as trucks where the key pushes an actuator which runs down the colum to the switch or is the switch somewhere else? What is the easiest way to install this!
Thank you!
Old Oct 30, 2002 | 08:48 PM
topo4u2's Avatar
topo4u2
Hi Brett, well personally I have not done a switch on an Explorer yet but I do own one, and yes Im sure the switch is set up like the usual vehicle with the actuator to the column. You might want to disconnect the battery when you do it. There is the yellow airbag wire running through there and I would hate to see an accident.
Mike: 1995 Explorer XLT,4.0 litre, 3.73 non-slip.
Old Oct 30, 2002 | 09:46 PM
Dialtone's Avatar
Dialtone
baja030
25
Jan 27, 2017 07:48 AM
ccaissie
Oct 31, 2016 11:05 AM
Texasdeereandhorse
Oct 26, 2016 01:22 PM
1998Ranger25L153CID
May 4, 2016 10:22 PM
Truck1995
Dec 12, 2012 07:00 PM
