Throttle Body Cleaning
Old Jun 28, 2003 | 10:23 PM
jcandrew's Avatar
jcandrew
Throttle Body
Good info in this thread--thanks to you guys I successfully cleaned my first throttle body today! My truck still pings a little but I think this was more due to load of gravel in back and having AC on. Just curious, but my manual says to change plugs every 100,000 miles but I have heard it isn't a bad idea to change them around 60,000 miles. What do you think? I have also never used a torque wrench to install spark plugs and haven't stripped anything yet or had problems. Does one really have to use a torque wrench?
Old Jul 4, 2003 | 08:07 PM
Bob Ayers's Avatar
Bob Ayers
Throttle Body
I pulled the intake tube off my 3.0L FFV today, and the MAF &
throttle body were spotless!!! It just turned over 76K miles, and
I have always used the OEM paper type of filter, never a K&N!!
Old Jul 4, 2003 | 08:59 PM
Rockledge's Avatar
Rockledge
Thumbs up Throttle Body
That's gotta make you feel good Bob....if the TB and MAF are clean after 76K then you have to think the rest of the engine is in good shape in that regard!
Old Jun 24, 2004 | 01:22 PM
oledog's Avatar
oledog
? Shouldn't you remove the TB to clean it? I'm new to EFI on Fords. But on a 5.7 L98 I always took the TB off and used TB cleaner.
Just Askin'
Old Jun 24, 2004 | 08:45 PM
agelder's Avatar
agelder
Kinda hard in older 3.0s which had integrated TBs
Old Jun 24, 2004 | 10:57 PM
99xlt4.04x4's Avatar
99xlt4.04x4
Just a little note, the lining is teflon (no- stick stuff on frying pans) On my can of TB cleaner it says "Teflon Safe" i would look for this label just to make sure you dont clean it off. But in any case, you would just have to clean it more.
Old Jun 25, 2004 | 01:57 AM
Torque1st's Avatar
Torque1st
Posting Legend
I cleaned the TB on my 98 with either carb cleaner or brake cleaner, I can't remember which. It wasn't until it was clean that I could see the warning label. Oh well, I will just have to watch for a buildup. The inside of the intake manifold is absolutely filthy. Carb manifolds don't get filthy like this one is.
Old Jun 25, 2004 | 08:32 PM
Rockledge's Avatar
Rockledge
IMO, a clean throttle body - even with the protective coating faded/removed by using a harsher cleaner than what is recommended - has to be better than a filthy TB with the protective coating completely coated over by a layers of accumulated dirt, carbon, etc.
Old Jun 26, 2004 | 08:30 PM
JEY's Avatar
JEY
Have an 01 Ranger, 3.0 with automatic, 2 wheel drive. I have never cleaned the throttle body. The truck is just short of 100,000 miles. I have used K&N filters for the last 19 years. This is my truck used for business, I fill up at the end of the day for the start of the next day, around 8 to 13 gallons a day. The engine is in great shape, no leaks, no oil consumption (change every 5,000 mi.). The conditions are highway and off road, ie: rock quarries, construction sites, etc.
I assume most of the dirty throttle bodies are short mileage (per day) situations?
Just some input from my end.
Old Jun 27, 2004 | 01:18 AM
LxMan1's Avatar
LxMan1
A lot of the build up in the TB comes from the crankcase blow-by that is usually introduced into the system from the breather tube from the valvecover to the air intake assembly. This is quite common on higher mileage vehicles.
Oh, by the way, My 88 5.0 Stang has had a K&N filter for over 150,000 miles and I have never had to clean the MAF or TB. The K&N filters only soil them when too much oil is put on them. I also run one in my 2001 F150 and I have had no problems either.
Old Jun 27, 2004 | 04:14 PM
JEY's Avatar
JEY
I agree with you Jimmy, the proper maintenance of the K&N filter is the key. I have no engine wear, that is no oil consumption and no blow by. All my vehicles are high mileage in three to three and a half year periods. Buy a new filter with a new truck, period. Throttle bodies, etc no problems.
JEY
Old Jan 3, 2005 | 05:50 PM
tonetls's Avatar
tonetls
what about cleaning a 2.3 dual plug TB?
Old Jan 22, 2006 | 09:14 AM
  #28
98-Ranger's Avatar
98-Ranger
Guy's,
Looked in my throttle body, lots of crud!
Question, do you remove the throttle body to clean it? If so, is there a gasket to replace?
Looks kind of tough to clean with the thing mounted to the intake manifold.
Old Jan 22, 2006 | 09:59 AM
  #29
Rockledge's Avatar
Rockledge
No need to remove the TB, I suppose you could if you wanted, but the method most people use is to keep the engine running while applying short blasts of carburetor/throttle body cleaner to the dirty parts. The stuff get's sucked into the combustion chambers and burned out the exhaust. You're probably gonna have to keep one hand on the throttle lever so that you can increase RPMs while the stuff is getting pulled in and burned. The process obviously loosens up the coke and carbon in the TB as well as the upper intake, to some degree. Expect some smoke out the tailpipe.
Along the same lines, you might want to think about performing another 4.0L intake "cleansing" procedure while you are at it, that way you'll know for sure that the whole air intake system on the engine has been treated.
https://www.ford-trucks.com/forums/s...hreadid=100739
You can substutute a similar product (i.e., SeaFoam) for the Motorcraft Tune-up Cleaner PM-3.
Budman1962
2009 - 2014 F150
Jun 20, 2016 09:23 AM
Brad Didit
Modular V8 (4.6L, 5.4L)
Mar 14, 2016 03:22 PM
AVR2
Escape & Escape Hybrid
Jan 15, 2016 02:07 PM
meck1
1983 - 2012 Ranger & B-Series
Sep 15, 2010 03:59 PM
99expyTN
Apr 4, 2004 09:16 AM
