99 - Cleaning throttle body
Old Feb 29, 2004 | 03:44 PM
99expyTN's Avatar
99expyTN
I have to clean the throttle body on my expy about every 5k miles...the gas pedal really begins to stick (very irritating when maneuvering around a parking lot). For those of you who have to clean the throttle body, how often do you have to do this? Is every 5k miles normal. I bought the truck with 66k and it now has 80k miles on it, and I've cleaned the throttle body three times.
Thanks,
Philip
Old Feb 29, 2004 | 06:43 PM
The Hog's Avatar
The Hog
According to the lil sticker on my TB there is a special coating on it and it says "CAUTION: DO NOT CLEAN THROTTLE BODY. IT HAS A SPECIAL COATING THAT WILL BE REMOVED" or something along those lines.
Old Feb 29, 2004 | 10:12 PM
buzzard's Avatar
buzzard
Are you cleaning the inside or outside? Regardless, you shouldn't have to maintain it every 5K miles unless you're in extreme conditions.
Hog is correct, Ford recommends not using a cleaner on the inside, but the only alternative is to buy a whole new TB if one is dirty.
Old Feb 29, 2004 | 10:15 PM
tsdrallyer's Avatar
tsdrallyer
I have 125K miles on my truck. I've had to clean the throttle body due to sticking only once, around 90K. After I over-oiled the K&N. I used a little mineral spirits (paint thinner) on a soft rag and wiped it lightly to remove the black stuff. Did both body and butterfly. Let dry. No problems since.
While you you have the induction tube off, use a little rubbing alcohol on a Cue Tip and gently clean the MAF sensor wires. Let dry. Reassemble. New truck!
Old Feb 29, 2004 | 11:04 PM
turbo TED's Avatar
turbo TED
99expyTN; Use the throttle plate and intake cleaner made by
3M,It is safe to use on coated throttle bodies and plates, it is a very effective cleaner for this job. Just be sure not to saturate the shaft on the TPS side or this may potentialy contaminate the TPS and render it useless or worse it may cause a sudden accelaration
type effect. Also use this product on the mass air flow sensor, just a word of advice make sure the throttle plate remains open for a little while after you have sprayed the entire bodie or else it could back fire.
Keep us informed
Turbo Ted
Old Feb 29, 2004 | 11:24 PM
mtn boomer's Avatar
mtn boomer
Hey Philp, I cleaned mine at 110K miles and I used a rag with some carb/choke cleaned on it. Just wiped around the the edge where the plate touches the body and the outer edge of the plate. No more problems. There was an earlier thread that said that Ford had trouble with holes in the castings of the throttle body and thats why the coating is there. Good Luck!
Big Dave
Old Mar 1, 2004 | 07:07 AM
99expyTN's Avatar
99expyTN
The first two times I cleaned the TB, I used mineral spirits. This past time I bought a TB cleaner (said it was safe for coated TBs). To clean it, I remove the air intake, hold the butterfly valve open, and spray around where the valve would touch the body. I then take a clean rag and wipe around the body itself and then the edge of the butterfly valve. The rag always comes back coated with black residue.
After each cleaning, the throttle works great......no more sticking. We'll see how long it last this time. Also, I don't do any extreme driving, off-roading, etc.
Thanks for the replies,
Philip
Old Apr 3, 2004 | 09:35 AM
CrumpDogg's Avatar
CrumpDogg
If you are getting extreme carbon build up every 5K, something else is wrong. Check EGR for clogs along with associated hoses.
Old Apr 4, 2004 | 09:16 AM
ThomasDooley's Avatar
ThomasDooley
If your year of Expedition has a PCV valve, and it vents into the throttle body area, you might have excessive blow-by.
I believe the coating was to keep stuff from sticking to the TB.
Tom
Budman1962
2009 - 2014 F150
Jun 20, 2016 09:23 AM
dudewayne
Dec 2, 2015 03:45 AM
pdqtimetrialer
Aug 27, 2012 07:17 AM
tankeryanker73
Jul 1, 2010 02:43 PM
bmark
1978 - 1996 Big Bronco
Jun 16, 2002 12:20 PM
