Head info
Old Jun 25, 2004 | 05:08 PM
bigunde
Guest
Posts: n/a
Head info
What is the difference between a 89 351w fuel injection head and a 85 351ho w head???cc's etc???Thanks and great site.
Old Jun 25, 2004 | 05:36 PM
bigunde
Guest
Posts: n/a
head info
is there any difference in the 35w ho head from 1985 and the 351w head on a 89 fuel injection engine?
Old Jun 25, 2004 | 07:53 PM
jwtaylor's Avatar
jwtaylor
Could be, need to know the casting number to be certain. There is a chance the 85 351w has E5TE heads and the 89 302 or 351w (you didn't specify doesn't really matter though) either would more likely than not have E7TE heads unless someone changed them. The E5 have 69cc chamber and the E7 have 64cc chambers otherwise they are the same head, except the head bolt holes are specific to either 351w or 302, either way you can make them work. If the 85 does not have E5 heads and is using another early 80's or late 70's production head, then the 89 model are better slightly as far as flow and hp/tq potential and in naturally aspirated applications the smaller cc chambers are desired somewhat. Hope that helps
v10squirrel
Jul 10, 2007 08:54 PM
kc8fhs
Oct 19, 2002 08:37 PM
GendoIkari69
Feb 26, 2002 10:30 PM
airharley
Feb 19, 2002 01:34 PM
fordzrule
Dec 31, 2001 10:37 PM
