Front Windshield Wiper Problem
Old Nov 3, 2002 | 02:05 PM
pbraiden's Avatar
pbraiden
Post Front Windshield Wiper Problem
Hi, I need some help. I have a 1996 Explorer where the front wipers only work on the high setting. The intermittant settings don't work at all.
I've checked all the fuses and everything is okay. I don't suspect the wiper motor because the wipers still work on the high setting.
Has anyone else run into this problem? If so can you pass on what the fix is or experiences in tracking down what the problem is.
Thanks,
Paul
Old Nov 3, 2002 | 05:33 PM
zimzimma's Avatar
zimzimma
Sounds like a bad multi-function switch to me. Try swapping it out and see what you get.
Jon
1998 Explorer XLT
1993 Bronco XLT
Old Nov 3, 2002 | 05:49 PM
zimzimma's Avatar
zimzimma
Old Mar 11, 2003 | 08:01 PM
Wiggrp's Avatar
Wiggrp
Hello Paul;
Our '96 Limited Explorer is suffering exactly the same winshield wiper symptoms you described in your message. Was the multi-function switch the culprit? If so, did you change it yourself? Do you have a step by step for that process? If it wasn't the multi function, could you please advise as to what the problem turned out to be?
Thanks. Mike
phoneman91
64
Feb 2, 2025 05:40 PM
gmhorse
6.7L Power Stroke Diesel
163
Jul 6, 2020 09:16 AM
AndysFords
Nov 11, 2015 08:15 PM
RIKIL
Oct 4, 2015 11:44 AM
Josh S
1983 - 2012 Ranger & B-Series
Aug 25, 2015 06:28 AM
