Our '96 Limited Explorer is suffering exactly the same winshield wiper symptoms you described in your message. Was the multi-function switch the culprit? If so, did you change it yourself? Do you have a step by step for that process? If it wasn't the multi function, could you please advise as to what the problem turned out to be?
