Collapsed Upper Radiator Hose
Old Jun 25, 2004 | 10:07 AM
emba129's Avatar
emba129
I have a 94 Explorer XLT 97K mi.
I was looking under the hood, with the engine cold, and noticed the upper radiator hose collapsed flat. I never changed the hoses so I plan on starting with changing it. I am just questioning if it is actually a failing hose or what is causing a "vacuum" that would cause this to happen. I changed the thermostat about a year ago.
I have added a few bottles of stop leak over the past couple of years to cure a seeping radiator and plan on replacing the radiator when it starts again.. but so far no leak anywhere
Any thoughts?
Old Jun 25, 2004 | 10:47 AM
jfsledge's Avatar
jfsledge
Try cleaning/replacing the radiator cap. It is supposed to allow coolant to flow back into the radiator when the engine cools and into the overflow tank as the engine heats up. If it doesn't work properly, as the engine cools, the coolant contracts and the overall volume goes down. The fault in the radiator cap can be seen in the upper radiator hose collapsing as a pressure drops in the system. It may be that the leak stop has crudded up the radiator cap, and thus it doesn't lift and shut properly.
Old Jun 25, 2004 | 07:01 PM
LV Dan's Avatar
LV Dan
While the radiator cap is a most likely suspect, there are other areas that can block the return. There is a hose that runs between the radiator and the holding tank for the extra coolant that can plug. Also, check to see if there is something at the bottom of the coolant over flow tank.
Remember that stop leak is meant to plug holes and does not know which holes to plug and which not. Sometimes it plugs the necessary ones!
Old Jun 25, 2004 | 08:06 PM
srercrcr's Avatar
srercrcr
Recommendation: Whenever youre going to replace some part of the cooling system, replace everything...coolant, hoses, thermostat.
tony montana 42
6.7L Power Stroke Diesel
Jan 5, 2016 06:52 PM
chesster51
Sep 26, 2015 02:10 PM
xxcbonexx
May 23, 2011 09:56 PM
88fordranger
Dec 12, 2005 07:32 PM
Manwith3fords
Jul 20, 2003 08:53 AM
