top radiator hose
Old Jul 19, 2003 | 08:13 PM
Manwith3fords's Avatar
Manwith3fords
Question top radiator hose
I just bought my 88 F150, 5.0/C6 and the top rad hose collapses when the engine cools off. It does not pull any coolant from the overflow either. I replaced the rad cap and still no change, I think the thermostat may be stuck open as the engine runs very cool. I plan on doing a cooling system flush soon and will throw another thermostat in it then, any other ideas as to what might be causing this? I am a truck and transport mechanic and have done all the usual checks, maybe I am missing the obvious?
Old Jul 19, 2003 | 10:04 PM
Manwith3fords
top radiator hose
ttt
Old Jul 20, 2003 | 08:53 AM
jim henderson's Avatar
jim henderson
top radiator hose
Old hoses will often collapse either on cool down or more troublesome, during high RPM which then causes over heating .
Either the spring that is in some hoses is worn out and needs replacing or the hose is old and needs replacing.
Good Luck,
Jim Henderson
rj1983
Jan 10, 2017 12:37 AM
Berardini2121
1978 - 1996 Big Bronco
Apr 22, 2016 11:49 PM
48f68
Apr 2, 2016 09:29 PM
One79one71
13
May 18, 2011 12:13 PM
coplin
Nov 9, 2005 10:20 AM
