Axle Tag
Old Jun 24, 2004 | 11:37 PM
wcmo sae's Avatar
wcmo sae
Axle Tag
I'd like to decipher the tag on my rear axle to see if it's still the original with the truck. The appearance and the performance of it don't exactly match up with the ale code on the door jamb, at least in my opinion. Also, I'd like ot find out if it's a limited slip or not. if needed, I'll post it here later. Thanks for any help.
Old Jun 25, 2004 | 08:44 PM
andym's Avatar
andym
Unfortnately, there's no way to see if the axle is the original. About all you can do is see if the axle ratio printed on the tag matches the one on the door sticker.
Old Jun 25, 2004 | 10:59 PM
wcmo sae's Avatar
wcmo sae
That's what I was meaning. I haven't actually looked at the tag yet. I just saw that there was one. I didn't know if there was a ratio printed on it or if the code needed to be deciphered......
One reason I was asking was because the rear lugs look like they're longer than the front ones, almost like they're meant for a dually. How can I tell the difference (if any other than the lugs) between the 10.25" and whatever is used in the duallies??
Old Jun 25, 2004 | 11:16 PM
andym's Avatar
andym
The dually axles are all Dana axles, unless I'm mistaken. The Dana axles have 10 bolts on the inspection cover, the Sterling axles have 12.
I think if your axle was a dually axle, you'd know it. All the dually axles I've seen up close look WAY different.
Old Jun 26, 2004 | 09:17 PM
wcmo sae's Avatar
wcmo sae
well, i have nothing to compare it to. I plan on crawling under tomorrow to check out the tag and, now, the number of bots on the cover.
I thought they were all Dana's (80??), also, but I've heard someone say that sometimes they put a Sterling 10.5" in 350s, but I don't know if perhaps that might have been SRW instead of DRW. I'll let you know tomorrow.
Old Jun 26, 2004 | 11:30 PM
wcmo sae's Avatar
wcmo sae
ok, I cross-referenced myself and found out that I was getting numbers messed up.
Originally Posted by n578md
f350's have a Ford /Sterling 10.25" full-floating axle. Some trucks had Dana 70 or Dana 70HD (10.5") axles. You can tell the dana's by a number "70" stamped on the webbing on the side where the cover bolts up.
This is where I was getting those numbers. I guess this "webbing" where the 70 is stamped is just on the side of the differential?? If I'm wrong, please correct me. I still plan on crawling under tomorrow to take a look. I'll let you know what I find out because this is bugging the heck outta me!!
Old Jun 26, 2004 | 11:43 PM
psdpower's Avatar
psdpower
If its a Super Duty it has a Sterling 10.50 rear. The axle tag should have 2 lines of numbers on it. The bottom line is the ratio and whether or not it has a limited slip. It will read something like 3L73. 3:73 being the ratio and L for limited slip.
Old Jun 30, 2004 | 10:56 PM
wcmo sae's Avatar
wcmo sae
Well, it's a 10.25 for sure (12 bolts). The tag does have 2 lines on it, but I can't read all of it. The main part I'm wondering about is it says, the best I can read, "55 10 ......" I might try to take the tag off tomorrow to clean it up and read it a little better.
Old Jun 30, 2004 | 11:38 PM
johnsdiesel's Avatar
johnsdiesel
All of the older pre-superduty trucks (not sure how far back) had the Sterling 10.25" rear axle, dually and SRW. Ford didn't start using the Dana 80 in the rear until the 1999 model and the rear end became the Sterling 10.5" on the SRW trucks.
nicksorenson
Jul 23, 2014 05:30 AM
MikePacey
Feb 25, 2011 08:00 PM
greatdays2gether
Sep 18, 2010 02:03 PM
MikeWire
17
May 29, 2007 05:29 PM
MonatheGrona94
May 16, 2007 09:34 AM
