79 f250 4x4 front axle tag I.D.
Old Feb 25, 2011 | 02:28 PM
MikePacey's Avatar
MikePacey
I'm taking a break right now from getting my engine ready to pull and so I was under the truck pulling the fuel line off the pump and decided to check my front axle diff cover tag and the like number and the right bottom coner of the diff.
The code at the bottom right is C38
The tag on the diff cover reads
09 D9TA AZA 610069-4
Can you guys give me some info about my front axle?
I don't know if this helps or not but I do have power steering and I do have a sway bar.
Old Feb 25, 2011 | 02:55 PM
Jon Hess's Avatar
Jon Hess
Just type what's on the tag into google or bing and it should bring up all the info on the axle
Old Feb 25, 2011 | 06:33 PM
evam350's Avatar
evam350
Dana 44, 4.09 gears
Old Feb 25, 2011 | 07:32 PM
MikePacey's Avatar
MikePacey
I've also noticed its a high pinon is that good or bad?
Old Feb 25, 2011 | 08:00 PM
evam350's Avatar
evam350
All 78/79 F250s have high pinion front axles, that is a good thing.
It is stronger, gives more ground clearance and better driveshaft angles.
abosely
Mar 27, 2016 05:37 PM
poulton
Aug 5, 2015 06:22 PM
todd jo
Apr 4, 2007 10:32 PM
gab712
Dec 9, 2006 04:29 PM
frdtruc1
Mar 28, 2005 07:42 PM
