What rear end lube do I need?
on
1 Post
It's a 1990 E350 cutaway van motorhome, 27-foot, with a 460 V8. The tag on the differential (what I could make out anyway) says:
First line: 4.10 *F0
There was a downward pointing triangle where I have a star, and I am not sure if the last character is an O or 0.
Second line: 605421-2
On the pumpkin casing is what appears to be: D5AOD
And on the casing web (between pumpkin and axle hole: 70-2U
There was one other thing on the casing, but I couldn't make it out.
I need to know what weight axle lube to use. Hoping to use Redline.
Thanks
Thanks
yardbird
16
09-27-2023 08:04 PM
xtal_01
08-28-2015 08:51 AM
Notmeofficer
Large Truck
07-08-2011 08:17 AM
Bender99
01-30-2009 04:43 AM
6054212, c6az19580e, dana, differentia, end, eswm2c105a, ford, gear, lube, m702u, mercury, mountaineer, oil, part, rear
