4wd
Old Jun 24, 2004 | 06:53 PM
lamlee44's Avatar
lamlee44
4wd
I have this problem with my expedition 99. I bought it and it had a bent axle on the drivers side rear. I had it fixed. I switch to 4wd hi or low and the truck acts sluggish and makes bumping clanking noises. and when in reverse it seems as if it's going to lock the wheels. Does anyone have any answers that could help me? Mike
Old Jun 24, 2004 | 08:52 PM
BlueBobbyBird's Avatar
BlueBobbyBird
Everything seems OK in AWD? This may be a stretch...
When you had the axle fixed, was just the shaft replaced, or the entire axle? If the entire axle was replaced, you need to make sure the rear axle ratio matches the front. In 4WD, I believe the transfer case differential is locked and a different front/rear ratio will do nasty things to the drivetrain.
Old Jun 25, 2004 | 08:06 AM
lamlee44's Avatar
lamlee44
4wd
Well the guyat the shop matched up the ratio and replaced the side that whas bad on the vehicle. I read that a 4wd was supposed to clunk and stuff due to the vehicle changing gears or something along those lines. I also read that I have auto locking that engage and I have to reverse to unlock them or something. But today I will go and try it again to see what the 4wd does after driving for about ten minutes or something like that.
Old Jun 25, 2004 | 03:10 PM
buzzard's Avatar
buzzard
My 4wd (hi) is fairly quiet and performs great. I've heard others complain about noises and such. 4wd low generally causes a few more creaks and groans and shouldn't be used on dry pavement.
Old Jun 25, 2004 | 03:38 PM
Iceman8984's Avatar
Iceman8984
Neither 4low or 4hi should be used on dry pavement ................. thats what the A4WD is for.
Old Jun 26, 2004 | 10:21 PM
tsdrallyer's Avatar
tsdrallyer
Ditto Iceman8984. 2wd or AWD on pavement. There are not supposed to be any noises, shudders, clunks or such when changing from 2wd to awd,or to 4Hi if on a slippery surface. There will be a chunk or clunk when shifting to 4wLo and back again.
If you had the axle replaced and it was Limited slip, it will make destructive noises if enough friction modifier was not put in the diff as the oil was changed. And, it will destruct if you continue to drive it making noises and vibrations. Usually a chattering sound when turning right from a stop.
healinhand
65
Jun 29, 2024 12:59 PM
mechdc
Jul 24, 2017 10:36 PM
WyattB7154
Bronco II
Jul 6, 2017 07:14 PM
ROBZ95XJ
Apr 22, 2012 09:13 PM
RIKen822
Dec 12, 2005 06:32 PM
