Throttle pedal question
Old Jun 24, 2004 | 05:20 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I've got a 97 250 crew cab auto 4x4, the pedal has a slight hold to it when applying then it goes nice and easy. I don't really notice it much, but when someone else jumps in the truck it sounds like they are trying to rev a standard Is their any way of making the pedal, don't know exactly how to say it, maybe more touchy? So their isn't a lil bit of a hold to over come before it starts to go?
Old Jun 24, 2004 | 07:28 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yes, there is. Crawl under the dash with a flashlight and on the back side of the pedal you can see the throttle position switch, and the little metal tab on it that is causing the problem. If you very gently bend that tab down so that it breaks contact with the idle validation switch earlier it will get rid of most of the dead spot in the pedal.
CountryBumkin
Sep 22, 2013 02:08 PM
Curt Bates
Jan 12, 2012 03:23 PM
SheepRancher
May 8, 2009 07:03 AM
askolepaul
Jan 23, 2005 03:25 AM
Snoopy1
May 7, 2004 09:52 PM
