1978 - 1996 Big Bronco
Front End Clunking
Old Jun 24, 2004 | 11:27 AM
topfisherman's Avatar
topfisherman
Front End Clunking
Just a week ago I replaced my radius arm bushings with some urethane ones because my old ones were worn out. Now I'm getting a clunking noise coming from the front. At first I thought the noise was coming because the new bushings have to get seated and then I would have to re-torque them. So, I re-torqured them (one was a little loose) and took it for a drive, but the clunk was still there. The noise only appears when I'm driving more than 15mph, anything less and it is dead silent. Any ideas what is causing this?
Old Jun 24, 2004 | 11:35 AM
Kemicalburns's Avatar
Kemicalburns
could be tie rods, bearings or brake calipers. jack the front end up and see if your wheel has any play to it.
late
Old Jun 25, 2004 | 06:50 PM
topfisherman
The last time I had the front end off the ground, everything seemed tight, but I will have to check it again. When I was driving it today, the clunking felt like it was right under the floor, where you put your feet on both the passenger and drivers side. What should the nut on the radius arm be torqued to? I just want to make sure I have it right. The clunking feels real strange like somethings really loose. What should I check on the caliper, just see if it's tight? Thanks for the help so far.
Old Jun 25, 2004 | 07:23 PM
bronco5.8's Avatar
bronco5.8
The torque spec for the nut is 120 lbs.ft.
Warr
Old Jun 28, 2004 | 04:46 PM
topfisherman
Thanks bronco5.8, I had them torqued to 110 lbs.ft. I torqued them to 120 and it didn't make a difference. I also jacked up the front and the wheels seem tight. Any more ideas to what is causing the noise?
Old Jun 29, 2004 | 02:15 PM
bronco5.8's Avatar
bronco5.8
topfisherman, ck your hubs maybe one or both are engaged.
Warr
Old Jun 29, 2004 | 03:28 PM
bossind's Avatar
bossind
Wheels will seem tight when you raise the truck cause now your ball joints are at another angle where there is no wear. Raise truck with tires about 3 inches off of ground and use a long bar to pry between ground and tire and move the wheel up and down and feel for loosness.
Old Jun 30, 2004 | 04:46 PM
topfisherman
Well today I was checking the front suspension for anything loose and I couldn't find much. Both the front hubs are set to free and I checked the shocks, they are both tight. Bossind, I tried what you said and there didn't seem to be anything loose, but I don't think I was using a long enough pry bar so I am going to try it again tomorrow. I hope its not the ball joints because I just had them replaced about 2 1/2 years ago. Also, when I was jacking up the front tires, I noticed that as the tires left the ground, they moved to be straight up and down. Before they were lifted off the ground, they were kind of slanted outward and the tires have begun to wear on the inside edge. Does this happen because some alingment bushings or something are wore out? Or could this movement be causing the clunking? I am looking into getting an alingment since it hasn't been done in a long time.
Old Jul 3, 2004 | 08:54 AM
gman88's Avatar
gman88
Did it clunk prior to replacing the bushings? If you removed your radius arm mounting brackets from the frame when replacing the bushings, there is a chance that the bolts holding the brackets to the frame are not sufficiently tightened, or one is loose. You could be hearing the noise from play between these brackets and the frame.
Old Jul 5, 2004 | 03:33 PM
topfisherman
Yes there was a slight clunking before I replaced the bushings, that is the reason why I thought the bushings needed to be replaced (one ended up being bad). After I changed the bushings to some urethane ones, the clunking became more pronounced and I can kind of feel the clunking on the floor boards of the truck. I also did check the bolts on the radius arm bracket and they are all tight. Thanks for all the ideas so far.
Old Jul 5, 2004 | 11:28 PM
jambroson's Avatar
jambroson
I have the same problem on my 1995 Bronco XLT.
It is the only problem I have.
Please post if you figure it out.
Josh
chief2007
61
May 21, 2019 05:18 PM
abranz
Jun 4, 2016 11:32 AM
wagne020
May 12, 2016 10:38 PM
Alex F
Sep 4, 2015 08:10 AM
JohnnyAirtime
Apr 28, 2015 12:52 PM
