Modular V10 (6.8l)
Low power on long grades
Old Jun 23, 2004 | 03:52 PM
97E350V10's Avatar
97E350V10
I have a 30 foot Class C motorhome on a 1997 E350 chasis with a V10. I pull a boat wieghing around 5000 pounds including trailer. When I go up a hill, the engine gets to a point where it just seems to have only a little power. I also notice at that time a rumbling sound (not metallic or pinging). I wondering if this lack of power being be due to the fuel filter or catalytic converter partially clogged. I don't have any problems on flat roads.
Old Jun 24, 2004 | 09:57 AM
Big Orn's Avatar
Big Orn
Welcome to FTE!
How many miles on the engine? Have the plugs been changed? Fuel filter? I suppose you have no "check engine" light...
Old Jun 24, 2004 | 02:01 PM
97E350V10's Avatar
97E350V10
It has about 35,000 miles on it. I bought it with 25,000 miles on it and I haven't changed the plugs or fuel filter. No engine light comes on indicating problems.
Old Jun 24, 2004 | 02:09 PM
Big Orn's Avatar
Big Orn
Plugs might be fine, but the fuel filter can really bog that engine down. Did the previous owner keep a maintenance schedule?
If he didn't I would change the filter first...anyway.
Old Jun 28, 2004 | 10:38 AM
97E350V10's Avatar
97E350V10
I changed the fuel filter this weekend. An easy job after you spend $12 for the special tool. When I took the old filter off and blew through it in the reverse direction, it required some pressure (just used my mouth) but I didn't see any debris other than some rust coloring in the fuel reminants. I haven't had a chance to load test it yet by hooking up my boat and finding a long hill.
One think I didn't mention before was that my gas mileage had become really bad on my last trip, around 6 mpg. I wouldn't think a clogged fuel filter would have any effect on gas mileage. Would this point to another problem like the catalytic converter being bad?
Old Jun 28, 2004 | 04:50 PM
clevelandjim's Avatar
clevelandjim
When I towed my 34 Ft 9000 Lb TT to Florida this past Christmas I had the same complaint about my 1999 V-10 van loosing power on hills. I bitched to everyone, but had I ever looked at the air filter? Of course not, and it was totally clogged wtih crud!!
If you haven't, please check your air filter.
Old Jun 29, 2004 | 05:37 PM
97E350V10's Avatar
97E350V10
I changed my air filter to a K&N before my last trip and it didn't eliminate the problem.
Old Jun 29, 2004 | 09:47 PM
68 351 bronc's Avatar
68 351 bronc
What kind of gross weight pulling the boat? How steep of hills, % grade are you talking?
Do you let it down shift to 2 while on the hills? 3,500 to 4,500 rpms on the V-10 is nothing.
Has the power problem gotten worse or has it allways seemed that way?
moosey78
Jul 30, 2012 01:45 PM
smartgreen007
Feb 22, 2010 08:18 PM
rgdowntheroad
Jan 23, 2006 12:58 PM
E350superduty
Modular V10 (6.8l)
Jun 13, 2005 09:22 PM
DougB442
Modular V10 (6.8l)
47
Jun 24, 2002 04:01 PM
