4.6L V8 troubles
Old Jun 23, 2004 | 03:31 PM
99Flareside's Avatar
99Flareside
4.6L V8 troubles
I have a 1999 Flareside, 4x4 automatic 4.6L v8.. It has started to blow blue smoke on start up if it has been sitting for a day or two.. and idles very poorly for a few minutes on startup as well.. I have just had the crank case seal replaced a week ago and that has not cleared up the problem.. i am having the spark plugs replaced this week due to the leaky crank case seal that wrecked them.. but would that have anything to do with the blue smoke??? It has lost a reasonable amount of bottom end power.. and when you step on the gas pedal right to the floor (like if you are passing on the highway) it makes this wierd noise and just doesnt want to go.. so if anyone can help please do!! thanks
Old Jun 25, 2004 | 05:40 PM
LxMan1's Avatar
LxMan1
Probably Valve seals on the smoke problem. I would guess the IAC (Idle Air Contol) on the idle problem.
Old Jun 28, 2004 | 07:57 AM
99Flareside
thanks.. i will definately check the iac out. apparently all the seals and gaskets are good.. we had that checked on the weekend
Old Jun 29, 2004 | 05:02 AM
caprichos4's Avatar
caprichos4
I believe he is refering to the valve stem seals as it is something you must remove the valve covers to inspect and usually you can't tell if they are good unless you remove them. Something that CAN'T be done by visually inspecting them.
Old Jun 29, 2004 | 07:25 AM
99Flareside
oh icic.. the dealer probably wouldnt have done that... the warranty is almost up so they are probably overlooking problems until the warrranty is done. It seems to be running a lot better now with the crank case seal and the new plugs. Would a dirty air filter have anything to do with it??
Old Jun 29, 2004 | 10:22 PM
97Centurion's Avatar
97Centurion
Rub my Belly
Not for the blue smoke it wouldn't. More than likely valve seals!
Old Jul 4, 2004 | 10:18 PM
JustinH's Avatar
JustinH
clean the mass air sensor with some electrical cleaner, and change the air filter when you are in there.
Old Jul 13, 2004 | 12:03 AM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Valve seals? the more I read about these modular engines, the more GM they sound!!! Older Ford engines were built right and they didn't need a seal to stop oil from flowing down the valve, like chevies do. That really sux and there's no excuse for it.
Old Jul 15, 2004 | 10:02 PM
LxMan1's Avatar
LxMan1
Ford always used umbrella type seals and they seem to last almost forever. GM used a seal that looked more like just a round gasket. They didn't last long at all. A friend of mine bought a 87 SS Monte Carlo AeroCoupe new. He had to have them replaced 3 timed during the 60,000 warranty. The early Mod engines had some issues with valve seals, but that has been fixed for awhile.
