Sponsored by: Kumho
when i turn, it pops
Old Jun 22, 2004 | 09:52 PM
Cool1996's Avatar
Cool1996
i have a 1996 f-150 4x2 the front end seems to crackle or pop when i turn the wheel or go down a curb, etc. the truck does not hold the road like it used to and metro 25 tire told me there was play in the pr steering box but i don't think the cracking sound was from the steering box. what should i check or do. i don't know where to start
Old Jun 22, 2004 | 11:26 PM
FordPerf300's Avatar
FordPerf300
I think all fords of this era suffer from the same problem. The engine crossmember rivets loosen up and when you turn the crossmember slides and bangs withing the loose rivets. Mine does it to, Way to fix this is grind out the rivets and replace with grade 8 bolts.
Old Jun 23, 2004 | 05:39 PM
Cool1996's Avatar
Cool1996
if you are talking about the crossmember under the tranny, it has bolts instead of rivets that must have been put in by the previous owner. could it be the radius arm bushings, ball joints, tie rod ends or the pr steering box???
Old Jun 28, 2004 | 11:25 PM
Cool1996's Avatar
Cool1996
hello anyone?
Old Jun 29, 2004 | 12:12 AM
mrwizard's Avatar
mrwizard
He was talking about the crossmember the engine and front axles attatch to. And, yes, it could be the radius arm bushings, ball joints, tie rod ends or power steering box. Get under the front of the truck while someone else turns the steering wheel back and forth slowly and look for any movement that shouldn't be there.
Old Jul 8, 2004 | 02:52 PM
Cool1996's Avatar
Cool1996
if those rivets are loose could i just run a bead of weld around the crossmember? if the radius arm bushings are bad will it pop and wander on the road. it wanders alot, could it be something else?
Old Jul 9, 2004 | 10:51 AM
FordPerf300
If it wanders that could be ALOT of things, yes, old worn radius arm bushings will cause a pop when turning and will cause wandering. Wandering could also be cause by bad wheel bearings, bad tie rod and drag link ends, loose steering gear box. To fix the frame rivet problem you have to grind out all the old rivets and replace with grade 8 bolts, welding will work, but not for long.
Old Jul 9, 2004 | 10:54 AM
Cool1996's Avatar
Cool1996
one more stoopid question, what is the drag link ends. isn't that the pitman arm
Old Jul 9, 2004 | 11:06 PM
FordPerf300
On a TTB setup, which you have you have one rod that run from the pitman arm to the passenger side knuckle, part of the way down there is another rod that runs to the drivers side. At each connection point there is a tierod end, which is just a ball and socket joint that allows rotation, after time they wear out and get really sloppy and allow side to side movement, which will cause wandering.
MurderMode
Oct 14, 2012 08:53 AM
viperbluelx
Nov 18, 2007 01:19 AM
BASSHUNTER
Jul 18, 2007 10:37 AM
SproutW
1978 - 1996 Big Bronco
Jan 31, 2005 02:02 AM
