hesitation
Old Jun 22, 2004 | 02:58 PM
redygo's Avatar
redygo
hesitation
my 95 powerstroke just started doing some weird stuff. it hestiates (like it flames out for a second) intermittently at around 1400rpm at light throttle and light load only in the first couple of gears, and sometimes it bogs below 2000rpm but at higher rpms it runs perfect. i changed the cam position sensor but nothing changed. any ideas? what shoiuld i check?
Old Jun 22, 2004 | 03:43 PM
78fordman's Avatar
78fordman
check fuel pressure, sounds like your pump is on its way out. Most auto parts stores should have the specs for the truck and i know autozone or advance auto parts will loan out the gauge for little cost.
Old Jun 22, 2004 | 03:49 PM
redygo's Avatar
redygo
thanx ill check it out
Old Jun 23, 2004 | 03:39 PM
redygo's Avatar
redygo
i checked fuel pressure and its fluctuating betwwen 50-60psi, when i press the throttle it goes close to 80psi, i read the fuel pressure should be 40psi, is this correct? could this be my problem?
maitai 1
Sep 9, 2013 02:43 PM
rocky3539
Dec 9, 2006 12:10 AM
sledhaus
1983 - 2012 Ranger & B-Series
Nov 14, 2006 11:23 AM
snipa
Nov 13, 2004 05:45 PM
tandlmack
Modular V8 (4.6L, 5.4L)
Oct 7, 2003 06:47 PM
