I ran the self test and got code 33. I tested the sensor on the egr valve and ended up replacing the EGR valve and the sensor on top of the EGR valve. Ran the self test agian and still get code 33. What do I do?
Check the EVR (mounted near the ignition coil) to see if it will hold a vacuum when it is closed. If it leaks vacuum, the EGR valve will open up when the computer is not expecting it to, and will throw a code.
All Fixed......Thanks for the advice. I finally got a hold of a freind and he told me it had to be reset with a computer. So I brought it to him......all fixed.
Thanks, I would like to know. I have heard of computer settings on GMs that are modified and then next time you disconnect your battery, you lose the setting and it has to be set again. This doesn't fix anything it just keeps from setting and error code and the check engine light. If he did something like that you should know what to expect.
On the other hand, maybe clearing the codes just didn't take when you disconnected your battery cable.
