CD Changer question
Old Jul 4, 2004 | 08:42 AM
K2JJB's Avatar
K2JJB
Originally Posted by friech
I have a '97 X with the OEM CD changer. I have had no problems running CD-R's. I use TDK disks ( bought from costco) and burn them at 24X using a DVD burner.
Good info, I should try and see how far I can push my speed up before the truck complains about them. The suff I posted above is what I have found works best for me so that I can use all my players with a particular disc.
Old Jul 8, 2004 | 09:17 PM
jessman1128's Avatar
jessman1128
Well, I haven't had a chance to try anything else regarding burned cds because the cd changer stopped working again. I'm now having the same problem I originally had - it pulls the cds in, tries them all one at a time, gets through all of them and flashes "NO CD" on the display. I tried the cd cleaner again a bunch of times with no success.
I proceeded to remove the changer from the center console, and take it partially apart. I got the front cover off and then the top cover off so I could at least partially see inside. I couldn't see any problems that way so I took it back out to the Explorer in its partially disassembled mode, plugged it back in, and watched as it went through the process of pulling in each cd, holding it for a few seconds, then spitting it back out. The only definite thing I can tell is that the player is not spinning the cds at all. I'm assuming that this is probably the only problem and if I can get that fixed it will start working again.
Does anyone have any ideas why it isn't spinning the cds? Do you know what spins the cds? Anything I can look for inside the player that might help me out?
Thanks in advance for any information you can give me.
Old Jul 8, 2004 | 10:10 PM
clarko's Avatar
clarko
Yea I had the same problem but I can't remember how I fixed it, damn. If I remember how, I'll tell ya'll.
Old Aug 14, 2004 | 02:12 PM
18fan's Avatar
18fan
jessman1128 did you ever get your changer working. My daughters just started doing the same thing in her 95.I thought about cleaning but after I read your post I was not sure.
Old Nov 27, 2004 | 02:01 PM
jessman1128
Sorry for the extremely late reply 18fan...
Yes, I did eventually get the cd changer working in my Explorer. Apparently the first "cleaning" I gave it was not very thorough. My first cleaning involved using a CD cleaner disc and running it through the player 20+ times (see above posts). That helped a little bit, but not for very long (again, see previous posts). The second time around I took the changer out of the vehicle, took it inside, partially dis-assembled the case, then took a can of compressed air and blew it in every crack and hole in the case that I could get the compressed air straw through. I also blew it in the main opening where the cd cartridge goes towards the guts of the player, including between the rollers that grab the cd and pull it in. After doing this several times the player started working again. It's died on me a few times since then, or gotten worse to the point where it stops playing cds suddenly and flashes "NO CD". Each time it starts getting worse I either run the CD cleaner disc through it a few times, or blow some more compressed air into it.
I'm not exactly sure my theory is correct, but based on what I did to get it working, plus some information I obtained from various CD drive repair sites, I believe the CD disc sensor was dirty. Some cd players will not start the spinning mechanism until they can detect that a CD is present. I believe this was the problem on my CD changer - the sensor was so dirty that it couldn't see the cds, even though it was pulling them in fine.
It's possible this might be the problem with yours - or it might not. If you need help getting the changer out of the vehicle (should you decide to attempt this), let me know and I can try to provide you with some tips on how to go about doing it. It's not all that difficult, it just took me a little while to figure it out!
Old Nov 27, 2004 | 02:08 PM
18fan's Avatar
18fan
Thanks for the tip. I will try that and see if it works. Hers flashes the no cd everytime I try it. Thanks
brainDfect
31
Nov 24, 2017 09:55 AM
01gator
Jun 2, 2010 09:27 AM
fbodyfan
13
Jun 14, 2008 07:40 AM
D Ray
Dec 7, 2005 10:47 PM
cotoole
Jun 14, 2002 08:49 PM
