home made tymar????
Old Jun 21, 2004 | 05:26 PM
craneguy's Avatar
craneguy
Cool home made tymar????
hey guys I was looking thriugh some threads yesterday and I saw somthing about a home made tymay intake and now I can't find that thread can some one help me out?
Old Jun 21, 2004 | 05:32 PM
Quadzilla's Avatar
Quadzilla
Anyone who knows Dale Isley, and saw how hard he worked on developing the TYMAR intake, takes exception to the use of "home made" and TYMAR in the same sentence. You can come up with a home made intake, but then it wouldn't be a TYMAR, since it's a registered brand name.
Now that I'm off my soapbox, I'll try to answer your question:
You can put together a home made intake by using a 45degree elbow, some hose clamps, and a big filter. Several will work, as long as it's got a 4" opening. Whatever you do, it'll work better than the stock airbox. However, it still won't be a TYMAR.
Old Jun 22, 2004 | 12:32 PM
TJC1989's Avatar
TJC1989
I agree here. The Tymar filter system is more than just the paper filter. Its the trial and error development of the intake tubes and mountings, too. Even though I did not buy the Tymar, I came EXTREMELY close, before deciding on the AIS Ford system. My truck only had 26,000 miles, and warranty was a concern. So using "home made" and "Tymar" in the same sentence is a misleading suggestion. We all know what you meant, which is actually flattery in some ways to the Tymar, but perhaps folks should call it a "home made air filter system" when they want to build their own. Anyway, thats just my $.02 worth.
Old Jun 22, 2004 | 12:52 PM
johnsdiesel's Avatar
johnsdiesel
I agree with the above. If you didn't buy it from Tymar it's not a Tymar, it's a homemade open-element intake or whatever else you want to call it. I wouldn't call the do-it-yourself auxillary idle controller a homemade Ford idle controller and I wouldn't call a shimmed FPR a homemade California Regulator Kit. Similar, but not the same.
Old Jun 22, 2004 | 08:31 PM
aerobatx's Avatar
aerobatx
On my 2000 F350 I rigged up a air filter system using a Mack exhaust 45 and the inner filter of a 963 Cat. It cost a 1/4 of a K&N and is a better filter. { homemade}
Old Jun 22, 2004 | 10:16 PM
ltfox's Avatar
ltfox
Spend a little more more money and save yourself alot of time engineering and get the tymar. It gives ya more peace-of-mind also. my two cents.
Old Jun 23, 2004 | 12:34 PM
chipper's Avatar
chipper
Napa 6637 air filter $26.00
Old 4inch stainless exhaust pipe laying in the corner of the garage. Free
4 inch pcv pipe seal at local hardware $2.79
Spent your money how you like but less than $30 and a half hours work sounds great to me. Yes I know its not a "tymar" but it still doesn't the same thing. Filter air a whole lot better than the factory air box.
Old Jun 23, 2004 | 02:56 PM
stealth1's Avatar
stealth1
CraneGuy, I see you got alot of answers you didn't need. If you have not already tried, use the search option and you may have better results.Good luck..
Old Jun 23, 2004 | 06:24 PM
oppy's Avatar
oppy
Try here. Should be everything you ever wanted to know.
Old Jun 23, 2004 | 07:53 PM
1965Cobra's Avatar
1965Cobra
Tymar? No. Didn't like the filter. K&N? I like. Ordered a RC-4780 ($48.93) and will get a 45 degree 4" pipe from the local truck parts dealer. I think 200 bucks for $65.00 worth of parts is High in my book. I'll post a picture once I get mine installed.
My .02
Mike
Old Jun 23, 2004 | 08:39 PM
johnsdiesel
You like the actual K&N filter over the Donaldson? Based on what?
Old Jun 23, 2004 | 11:56 PM
farmb0y's Avatar
farmb0y
johnsdiesel- you know I like my K&N and will fight for it till the end. I personally like the oiled elment better, more proned to catch dirt, and I'm not buying a new filter when it needs to be cleaned as you have to do with the Tymar.
Old Jun 24, 2004 | 03:38 PM
1965Cobra's Avatar
1965Cobra
Yup, what John said and cause the Cobra has a K&N. Throw-away paper filters are OK but I'd rather pay 2x as much up from and keep using the K&N.
Mike
Old Jun 24, 2004 | 04:00 PM
johnsdiesel
Just curious. I thought you were saying that Donaldson makes bad filters which I would take issue with.
Old Jun 24, 2004 | 04:21 PM
craneguy's Avatar
craneguy
Talking
Thanks!!! that is what I needed.
BrizNasty
18
Feb 2, 2012 07:59 AM
bakerbuilttracks
Apr 16, 2011 12:40 AM
vvsarpsjr
Oct 4, 2010 06:50 PM
Prozon
Offroad & 4x4
16
Jun 27, 2009 03:47 PM
