Carb or Timing problem
Old Jun 20, 2004 | 07:03 PM
ratman-73ford's Avatar
ratman-73ford
The engine is a 360 in my 1973 F100 I just bought it 2 days ago. I keep getting blow back through the carb. When I try to burp the throttle from idle it misses, hiccups, and shoots a ball of fire out of the carb. Somebody told me it was a timing problem. What do you guys think? If it the timing how and where do I check it. This is the first carb engine Ive owned. So Im just learning and at 22 years old I just got out of the 4 bangers to the good engines. (V-8's)
Old Jun 20, 2004 | 09:09 PM
mark a.'s Avatar
mark a.
What led up to this problem ? Did somebody remove the dist. for some reason ?
Old Jun 20, 2004 | 09:25 PM
lee's Avatar
lee
Hi,
You need a timing light to check the timing. The light has a red and black wire which go to the battery. Then there is another cable with a black colored pick up that you put the #1 spark plug wire thru.
With the engine idleing, everytime the #1 plug fires, the timing light will flash also. Point the light down at the balancer from the drivers side and you should see some lines and numbers on the rotating balancer appear. Sometimes dirt makes it hard to see. These line up with a pointer sticking out from the engine. You change the "timing" by loosening up the distributor hold down clamp and slightly rotating the distributor. Don't forget to disconnect and plug the Vac advance line on the dissy first.
Adjust to specs.
Hope this helps,
Old Jun 20, 2004 | 09:30 PM
ratman-73ford
The person I bought it from replaced the dist.
Old Jun 20, 2004 | 09:32 PM
ratman-73ford
Thanks Ill give that a try
Old Jun 20, 2004 | 10:39 PM
65f100xmas's Avatar
65f100xmas
Does sound like a timing problem you will need a timing light to check you can get one at most part stores there should be instructions with it . Something like attach pickup to #1 plugwire etc timing marks are on the H. balncer at the front of the engine I cant remeber timing specs but I think Its 6 tdc. Iam sure some else will give you more help oop see I was right someone allready beat me to theb punch
Old Jun 20, 2004 | 10:43 PM
65f100xmas's Avatar
65f100xmas
If the dist was removed it may be 180 degrees out of turn easy to do if you dont mark it on removal
Old Jun 21, 2004 | 05:53 PM
F250-76's Avatar
F250-76
If the dist isn't 180 out, I would also double check the firing order. Had that happen on my 79 f-250 once. Just my.02!
Old Jun 21, 2004 | 08:05 PM
ratman-73ford
My book is missing a few pages. Came with the truck. I dont have the firing order does anybody have the firing order for my 73 360?
Old Jun 22, 2004 | 07:07 AM
tomw's Avatar
tomw
The firing order is cast into the top of the intake manifold. It will be a series of 8 numbers separated by dashes. Right near the words 'Firing order'. I think it is right near the front drivers side, but it's been years...1 8 5 4 6 3 7 2???
If it is not popping back when it is idling, (as in not missing, also) the firing order should be fine.
You can also get backfire if the accelerator pump is defective. It squirts a little fuel each time you press on the gas, to make sure the mixture does not lean out. If it is defective, you will also get hesitation on acceleration.
If the vacuum advance is too effective, you can also get backfire...
tom
Old Jun 22, 2004 | 07:47 AM
pops_91710's Avatar
pops_91710
Nope, it's 1-5-4-2-6-3-7-8 on all FE's.
Old Jun 22, 2004 | 08:13 AM
tomw's Avatar
tomw
Dang, those grey cells took a break... or was it a brake?
What you say looks right to me...wonder where I got that firing order in my head?
tom
Old Jun 22, 2004 | 09:16 AM
jor's Avatar
jor
The FE firing order is: 1-5-4-2-6-3-7-8. The rotor travels counter clockwise. The cylinders on the right side of the engine (looking from the driver's seat) are 1 through 4 (front to back) and the left side is 5 through 8 (front to back). Tom, that almost sounds like a Chevy (18436572)!
jor
Old Jun 22, 2004 | 11:25 AM
woods's Avatar
woods
I don't think the motor would start at all if the distributor was 180 degrees off.
the wires could be in the wrong firing order though
A carb problem probably would not send flames back through the carb
To check to see if the timing chain is loose,
You could remove the distributor cap and place a socket and wrench on the center bolt on the harmonic balancer and slightly turn the motor back and fourth clockwise/counter clockwise. the rotor should move immediatly when you move the bolt. There should be no slack at all. Maybe slight with chain wear. Might need to pull the sparkplugs for this.
Good Luck,
Ken
Old Jun 22, 2004 | 03:29 PM
pops_91710's Avatar
pops_91710
On a Ford, you can get the distributor out 6 different ways, not just 180 degrees. The distributor drive shaft is hex shaped, and so is the receiving (driven) end of the distributor shaft.
