1978 - 1996 Big Bronco
Engine Overheating
Old Jun 19, 2004 | 10:37 PM
harleynascar's Avatar
harleynascar
Unhappy Engine Overheating
I have a 79 Bronco with a 400. I have a problem with the engine overheating while traveling on city streets. The engine will run cool and then hot for a little while. Then it will go cool again and stay like that. I have replaced the clutch fan w/ a flex fan, thermostat, new coolant. Looking for help to solve the problem. I know that a shroud cover would help, need help locating one. Any info would be great. Thanks.
Old Jun 20, 2004 | 12:35 AM
fcarruth's Avatar
fcarruth
For the shroud, have you tried www.broncograveyard.com ?
Good luck,
Old Jun 20, 2004 | 01:07 AM
andym's Avatar
andym
Or try car-part.com.
What thermostat do you have installed?
Old Jun 20, 2004 | 08:29 AM
jsscart's Avatar
jsscart
Sounds like you might have a air bubble in the system some where.
Old Jun 20, 2004 | 10:28 AM
RTM's Avatar
RTM
I had a bad hose collapsing on me in the past shutting off the flow of coolant.
Old Jun 20, 2004 | 12:13 PM
harleynascar
Andym,
I'm not sure what type I put in, in was a couple of years ago. What do you recommend?
Old Jun 20, 2004 | 12:15 PM
harleynascar
jsscart,
What would be the best procedure to see if there is an air bubble. How to get rid of it?
Old Jun 20, 2004 | 12:17 PM
harleynascar
Good luck,
Thanks for the site. Checked it out and found some. Thank you.
Old Jun 20, 2004 | 01:24 PM
marv0's Avatar
marv0
Could also be the instrument cluster voltage regulator, really a wire wound resistor, behind the instrument cluster.
If the oil and fuel gauges also seem to read incorrectly when the temp gauge reads 'hot', it's probably the voltage regulator covered with dust and partially shorting out under humid conditions.
I had a double whammy with my '79 several years ago. The instrument voltage regulator causing false readings intermittently, AND unknowingly I had a fan clutch going bad. Ultimately, I replaced the clutched fan with a standard fan.
The voltage regulator resistor cost me about $17 at a Ford dealer, and it's a plug-in unit like a panel lamp and a pretty simple DIY twenty minute job.
Old Jun 20, 2004 | 01:43 PM
andym's Avatar
andym
You should be running a 195 degree thermostat. There's a lot of other good suggestions here too.
You might want to put in a real temp gauge, too. They're very easy to install, I have both an aftermarket temp gauge and oil pressure gauge in my truck, and they're worth it. The stock Ford gauges are pretty lousy.
If it really is overheating, you might try a cooling system flush. You can do it in your driveway in about an hour with a kit from autoznne and a garden hose.
