Help please!!!!!
Old Jun 19, 2004 | 03:05 PM
Bchezze22's Avatar
Bchezze22
Help please!!!!!
My 2001 Nav rear just dropped what could of happened. It's like I have no shocks!!
Help Please!!
Brian
Old Jun 19, 2004 | 03:44 PM
JustinH's Avatar
JustinH
sounds like the air suspension in the rear is shot, or sprung a leak.
If its under warranty with the dealer, take it to them, otherwise do not pay them to fix it. It will cost a fortune at the dealership.
Take it to a shop you trust and have them look at it before they start throwing parts at it that may not be necessary.
Old Jun 19, 2004 | 05:28 PM
Bchezze22's Avatar
Bchezze22
thank you
thanks for the suggestion, is there anyway I can check for leaks, I can't hear anything turning on when I start the car.
Old Jun 19, 2004 | 08:58 PM
myankow's Avatar
myankow
Is the suspension light on the dashboard on ? on my 98 nav there is a suspension switch on the passenger side used by the tire shops when aligning the front end. It is to shut off/on the suspension. Also have you checked the fuses? Do you hear the compressor coming on? You will not hear an air leak if the compressor is not pumping air. When, how, what caused you to notice this. what was the time between: everthing was ok to this is not right?
Old Jun 20, 2004 | 06:41 AM
Bchezze22's Avatar
Bchezze22
I was driving and hit a little bump, nothing to be worried about, but then I heard a small bang then when I got to where I was going I noticed my rear end was low. I pulle off the panel in the back where I think the air compressor is and I can't hear it turning on when Istart up the car. But I check for a switch and the fuse, but I have a funny feeling that the compressor died. where would the switch be in the front or the back?
Thanks for the help!!
Brian
Old Jun 20, 2004 | 07:54 AM
mapman's Avatar
mapman
On my 98 the switch is on the passenger side next to the floor
Old Jun 20, 2004 | 04:03 PM
Bchezze22's Avatar
Bchezze22
thank you for the help
Old Jun 20, 2004 | 07:31 PM
BigMan69's Avatar
BigMan69
The compressor is in the engine compartment on Expy's. I would assume it is there as well on Navi's.
BigMan69
Old Jul 9, 2004 | 05:28 PM
ckutter's Avatar
ckutter
A hose union just failed on mine. Exact same symtoms. They found the problem in about 10 minutes.
Old Jul 10, 2004 | 12:51 PM
99ExpeditionXLT's Avatar
99ExpeditionXLT
Sorry to hear about your Navigator. I think there are a few possibilities. Your Compressor failed, a line broke, or you have a blown fuse. I would not suspect a failed compressor as my first guess. More likely a line leak, or broken. Although you say you can't here the compressor running? Turn your ignition switch to the on possition without starting your Nav. Can you here it running? If not, check for a bad fuse. The fuse could have blown as a result of a broken line. A broken line would cause the compressor to continulally run to try to level the suspension. Once you have the compressor running, you should be able to trace down the leak. Hope this helps.
