Wiper Blades
Old Dec 3, 2002 | 11:21 AM
ckrichard's Avatar
ckrichard
Post Wiper Blades
Has anyone with a 91-94 explorer ever used a larger than stock wiper blade on the windshield? I was thinking that i might be able to a one or two inch larger blade on it.
Chris
Old Dec 3, 2002 | 02:18 PM
marrug's Avatar
marrug
Wiper Blades
Well absolutely. Bear in mind that for every inch you increase, you're only increasing 1/2 inch on either side of the center pivot point. Mine are 20" each, try to get the kind that have slots in the blade frame part, they wont lift up in the wind. The kind to stay away from are the double blades, the strain on the wiper motor causes problems. By the way; all of them seem to work about the same after a month or so, I wish i had back all the $$ I spent on sexy blades. Just wipe em off with alcohol occassionally and you're good to go.
Old Dec 4, 2002 | 12:41 AM
hrbib21's Avatar
hrbib21
Wiper Blades
I second the alcohol idea. I've spent (read as: wasted) numerous dollars and "special" wiper blades like Bosch and others, but I keep going back to Anco. Why? Well, they work the best if you take care of them.
Old Dec 4, 2002 | 04:05 PM
ckrichard's Avatar
ckrichard
Wiper Blades
Old Dec 8, 2002 | 06:20 PM
97 awd xlt blue's Avatar
97 awd xlt blue
Wiper Blades
i have 22in wipers on all my explorers
01 sport trac 4x4 black
97 explorer xlt AWD v8 blue
91 f-250 xlt lariat 4x4 blue/gray
84 ranger xlt 4x4 black
94 explorer xlt 4x4 purple/gray
96 explorer limited 4x4 green
i have 2 now they r identical i get really odd looks form the nabors now wonder y???
Old Feb 25, 2005 | 09:49 PM
dhoh1187's Avatar
dhoh1187
I use Bosch 18in and their great. They are a little more expensive but they last 4-6 months. (summer: 6 months, winter: 4-4.5 months)
Old Feb 26, 2005 | 06:55 PM
bulldog3531's Avatar
bulldog3531
I use Bosch 18in also and had them on my 98 Explorer for almost a 1 and a half years now and they still work great.
Old Feb 27, 2005 | 10:45 AM
norrislaketn's Avatar
norrislaketn
You can increase wiper blade size on any windshield if there is clearance and you have the correct blade housing. Keep in mind to keep the windshield wet because you now have increase resistance if it is dry.
dancraig
May 22, 2013 09:41 PM
mr. grieves
Mar 17, 2009 06:25 PM
uncle.stosh
20
Dec 3, 2008 07:26 PM
Fordcr
Jan 16, 2006 05:16 PM
