1978 - 1996 Big Bronco
O2 sensor stuck
Old Jun 18, 2004 | 09:19 PM
willystyle21's Avatar
willystyle21
Angry O2 sensor stuck
Figured it was about time to change it, so I do as Chilton's says to. Start the vehicle, let it warm up for a few minutes. Shut it off and loosen to sensor. Well, put a 7/8 crow's foot on a breaker bar and went to town on the sensor. It won, I couldn't budge it to save my life. Any idea's? I hate to think what would happen if I heated the pipes up and put WD-40 on them.
Old Jun 18, 2004 | 09:23 PM
andym's Avatar
andym
Lots of penetrating oil, and a torch.
I was real lucky. Mine popped right out with almost no effort.
Old Jun 18, 2004 | 09:44 PM
kumabronc's Avatar
kumabronc
Guys on this forum swear by PB Blaster penetrating oil. Soak it down every day for a week after driving and try again. Good luck.
Old Jun 18, 2004 | 10:27 PM
gumbyman38's Avatar
gumbyman38
change mine w/the o 2 tool from the zone(knocks on wood) so far so easy.try the oil,let it sit overnight I guess.good luck!!
Old Jun 18, 2004 | 11:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
Try the candle trick from the Garage & Workshop forum.
Old Jun 19, 2004 | 12:23 AM
gumbyman38's Avatar
gumbyman38
I have seen that mentioned before but didnt know what it was.I checked it out and here is a link from a torque1st post.<!--StartFragment --> https://www.ford-trucks.com/forums/s...candle+%2Btrick
if you are lazy like me,here is part of it.<!--StartFragment -->
This tip was posted by Hammerman3406 in another topic. It is a great idea.
The easiest and slickest way to deal with rusted-in bolts, regardless of where they are is as follows;
1. find a candle....yes, an ordinary candle from the kitchen drawer
2. get a torch. acetylene or mapp work best, but propane will do
3. heat the metal AROUND the offending bolt as hot as is practical.
4. feed the candle into the threads untill the wax quits melting
5. repeat 3&4 a couple of times
6. use an easy out or a pair of pliers (if a stub is left...)
I think that is a great tip!!
Old Jun 19, 2004 | 06:03 AM
genueix's Avatar
genueix
Do the scented ones work better?
Old Jun 19, 2004 | 01:45 PM
Trublufords's Avatar
Trublufords
Try cutting off wire end and use 6 point 7/8 deep socket, still stubbard- heat with a torch, remember threads are the same as old large spark plugs - you may have to chase (clean up ) threads.
Old Jun 19, 2004 | 01:46 PM
gumbyman38's Avatar
gumbyman38
Old Jun 19, 2004 | 04:00 PM
Artistictouch's Avatar
Artistictouch
All you have to do is warm your truck up or drive it and as soon as the exhaust is hot (too hot to touch) you can easily remove it with a wrench. Remember, metal expands with heat and shrinks when cooled off.
Old Jun 19, 2004 | 06:50 PM
andym's Avatar
andym
Right, but when you heat it up by running the engine, you also heat up the sensor, making it just as hard to get out.
Old Jun 19, 2004 | 07:19 PM
gumbyman38's Avatar
gumbyman38
no,it does make it easier,that is the recomended method for removal,he just said it didnt work for him when he tried it.
Old Jun 21, 2004 | 07:05 PM
willystyle21
Yep did the heating up trick just like I said I did right out of the chilton's book. No worky. Will have to try that cadle trick though.
Mi04f150
2004 - 2008 F150
Jun 28, 2016 10:27 AM
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
JoePeeper
Jul 7, 2013 07:40 AM
Adventure Rider
6.7L Power Stroke Diesel
27
Dec 29, 2012 11:30 AM
woodnthings
36
May 7, 2012 10:23 PM
