I installed new Rancho leafs in the rear of my cc f350 after breaking one of the factory ones.They are 3in higher than stock.At speeds 60 and faster im getting a vibration from the rear.Drive line angles all look ok.Any ideas from you suspention guys?
Well,I went for a ride and something sounded wierd on the hiway.I looked in the rearview mirror and the whole wheel was moving in and out.All the lugnuts fell off.Need less to say HOLY CRAP.So i took a fiew lugs off of the other wheels and limped home and got some new nuts.Now the vibration is gone.I thought for sure i torqued all the nuts after the spring change.Im starting to loose it .All that i feel now is a slight shudder on takeoffs.I just shimmed the center bearing but havent driven it yet.I hope this helps the shudder.What do you think?
Wow, lucky that didn't pop off. One day on the way home from work a car took a hard turn and had the whole wheel assembly pop off. That was kind of interesting to see sitting in the middle of the road.
