2001 Expedition hooking up the amp
Old Jun 18, 2004 | 09:10 AM
Dnice's Avatar
Dnice
Question 2001 Expedition hooking up the amp
I have a kenwood KAC-7285. The remote hookup is suppose to go to the power antena, but I don't have one, so what do I do?
Old Jun 18, 2004 | 09:55 AM
tyger25's Avatar
tyger25
That wire has to go to an ignition source. Find something that turns off when the ignition is turned off, and connect it to that fuse in the fuse box. Try the radio fuse.
Old Jun 18, 2004 | 09:57 AM
Dnice's Avatar
Dnice
Now if it's not hooked up, will that cause the amp not to get power even if you have the battery wire connected?
Old Jun 18, 2004 | 10:00 AM
tyger25's Avatar
tyger25
Yes. The amp has to have power to the internal switch to turn it on with the ignition. That internal switch is connected to the remote source.
Old Jun 18, 2004 | 10:10 AM
Dnice's Avatar
Dnice
That was it then! Thanks Man! I will let you know how it goes. Real quick, I printed out the breakdown of the audio wiring and they have a 12V+ Switched wire. Can I use that? There is a 12V+ Constant, but I think that one doesn't cut on and off with the radio.
Old Jun 18, 2004 | 10:13 AM
tyger25's Avatar
tyger25
Sure, use the 12v+. IF it doesn't turn off with the key, then you have to find something else.
Old Jun 18, 2004 | 10:15 AM
Dnice's Avatar
Dnice
Heck, i'm still trying to get it to turn on!
rockfordboy
39
Feb 28, 2003 06:51 AM
darkman
Jul 30, 2002 06:57 PM
John7894
Jul 14, 2002 06:43 PM
tetraruby
Oct 15, 2001 05:41 PM
proeliator
Offroad & 4x4
Aug 27, 2001 10:41 AM
