Hey guys I have a new truck well new to me a 86 f150 4x4 5.0 with overdrive.
The efi on the truck is in bad shape things missing and its running ruff .
I was thinking of putting a carb on it just a small 4 barl .
has anyone here done that and do you know if i will have to change the comp
and what not ? thanks for any help .
welderhound
well this is the first truck ive ever had with efi on it I really dont know where to start a buddy looked at it and helped me tune it up but it still run bad .
he works on cars and trucks for a living been doing it for 25 years hes the one that told me it was the efi .
I just wanted to put a carb on it I know little about them thats all.
if set up and operating properly efi is more efficiant than a carb. however efi costs a lot more to fix when it is screwed up. you gotta consider that some people actully do carb to efi swaps. efi gets a bit better gas milage something that is important right now.
Find someone who can scan the stored codes in your truck. Early Ford EFI is a bit picky about its tune. A bad sensor or something else minor might be causing your trouble.
Yes, EFI is a good thing. Most importantly, once you get an EFI system going and into good shape, it tends to keep going without much maintenance for a long time, and it doesn't have the drawbacks of carbs...
The best part of all is that most EFI systems are set up so that you can pull codes and it can "tell" you where it "hurts". Try that on a carb.
EFI _is_ a better fuel system than carbs. That is why you don't see carbs on new vehicles.
My suggestion is pickup a clinton's manual for your model year, and pickup a haines manual for 80-96. Combined, they have a boatload of good info.
Pull the codes, and start by posting what you pulled.
Btw, as horton-racing posted, in a lot of states now, if you pull the EFI, you won't be able to be inspected. Don't say you live in arkansas or something where they don't check, because eventually they will. PA never did, now they have an anti-tamping policy.
All of the above answers are true and correct. Particularly the issue that some states do not allow for changing anything that affects emissions. However, to answer your question, yes it is possible to remove the EFI system and replace it with a carburetor.
I personally enjoy tinkering and experimenting with different carburetors and manifold setups. But it is a hobby that may not be right for everybody. If you want the most reliable and economical system, stick with EFI. But, if hot rodding is in your blood and you enjoy tinkering with engines, you’ll probably find fooling around with carburetors a satisfying hobby. On the other hand, there doesn’t appear to be much you can do with an EFI system other that just drive it. Before you remove the EFI system, think about the pros and cons of the issue. Be particularly aware of what your local law allows.
I disagree- you can do a lot with EFI; however, the learning curve can suck.. EFI doesn't work as well when you are trying for 2000HP though.
