Clutch/Starter Sensor ?
Old Jul 8, 2004 | 10:46 AM
oldcoupe42's Avatar
oldcoupe42
Hi Jason, I went to my local Ford dealer to try and order the white retainer clip and while Im sure they tried their best they can't seem to get me the right part. By any chance do you still know the part number ?
Thanks, Chet
Old Jul 13, 2004 | 05:28 PM
firstonraceday's Avatar
firstonraceday
Chet,
Sorry it took so long to reply, I've been on vacation and just got back today. I'm sorry I don't remember the part number. I think I took waht was left of the clip to the dealer and they were able to get the right one. I disposed of the packaging when I had to get the master cylinder. i didn't get the impression that it was an unusual part, they seemed to keep them in stock.
Old Jul 13, 2004 | 05:40 PM
Redstallion924x4's Avatar
Redstallion924x4
i had the same problem starting my truck, it turned out for me, it was just the plastic clip that holds the clutch pedel arm to the push rod, my worn out to the point where it fell off, the clutch went to the floor and i was stuck in 2nd. the plastic clip was only a dollar or two at the dealer, if this is the problem, look at the arm on the pedel where it attacks to the push-rod, the guys at the dealer told me if the bushing wears to that point chances are you need to replace it too.... i did, its an easy fix though, good luck, Matt
92 f-150, 302, 5 speed, 8inch skyjacker/superlift, and 3 inch body lift, 38x15.50x15
Old Jul 13, 2004 | 07:14 PM
Talyn's Avatar
Talyn
my haynes manual says its an easy adjustment to change it.
and if your dareing, but i dont recomend this, just jump the sensor iwth a paper clip so you can start it with the clutch out.
Old Aug 6, 2004 | 07:11 AM
Len-Dogg's Avatar
Len-Dogg
Jumping the switch is exactly what I would like to do. Can you explain in more detail exactly what wires and or switch needs to be jumped? When I looked under there it wasn't as obvious as I thought it would be. Thanks!
Old Aug 12, 2004 | 02:14 AM
BCTruck's Avatar
BCTruck
I believe it's the two green wires going right into the switch that I jumped together
oldcoupe42
Aug 17, 2005 11:18 PM
oldcoupe42
Garage & Workshop
Jun 29, 2005 11:06 AM
chet copeland
Jan 22, 2005 12:18 PM
