Modular V10 (6.8l)
anyone running "Straight pipe"?
Old Jun 17, 2004 | 01:53 PM
GloNDark's Avatar
GloNDark
My buddy just got his "new to him" V10 and he is dying to get some more sound out of it.
We were talking about taking the cat out, and putting in a flowmaster 40 series. And he mentioned the O2 sensor behind the cat. So we aren't gonna touch that.
But then he was talking about cutting the muffler out and welding in a straight pipe. Anyone got this done already?
Old Jun 17, 2004 | 02:35 PM
Big Orn's Avatar
Big Orn
It must be a fairly newer model. My '99 didn't have the sensor behind the cat.
I have heard only one V10 with straight pipes - sounded like a Link Belt trackhoe on steroids - WAY TOO LOUD!
Old Jun 17, 2004 | 04:15 PM
68 351 bronc's Avatar
68 351 bronc
BigOrn, if your my age and your hearing is shot then it would probably be just right with strait pipes.
Old Jun 17, 2004 | 04:19 PM
Big Orn's Avatar
Big Orn
Or, our age and have been too long around loud heavy and light equipment that only had straights...
Old Jun 17, 2004 | 05:23 PM
GloNDark's Avatar
GloNDark
I think we will do his truck first and see how it sounds, if I like it I will do mine too. LOL
And no, not a new model. 2000 X-cab 4x4. My 99 Crew cab does NOT have the O2 behind the cat.
Old Jun 18, 2004 | 08:56 PM
V10man's Avatar
V10man
I didn't think any of the Superdutys had an O2 sensor behind the cat. No cat = LOUD!
Old Jun 18, 2004 | 09:26 PM
DJR 17's Avatar
DJR 17
I think you will lose low end torque, but the sound might make you want to rev it to 5500 rpm every gear!!
Old Jun 21, 2004 | 12:47 PM
Y2K350's Avatar
Y2K350
I had my muffler cut off and a stright pipe welded in place of it. It sounds good up until about 2500 rpm's then it sounds like an indy car, a very LOUD indy car. I'm thinking of putting on an exhaust tip and see if I can tone down the tinny sound. I haven't noticed any drop in low end torque. I pull a 12,000lb 5th wheel and it pulls just as well without the muffler as it did before. If anything I noticed an increase in throttle response.
Old Jun 21, 2004 | 02:05 PM
Saurian's Avatar
Saurian
But that Catalytic converter is giving you ALOT more of your backpressure then that muffler could ever give. If you remove it, you *will* lose some low end then. But you'll also pick up some of the higher end to compensate. Though..the 6.8 needs that low end to be what it truly needs to be.
Old Jun 21, 2004 | 06:43 PM
Y2K350's Avatar
Y2K350
I didn't remove the cat. That's illegal here and won't pass inspection.
Old Jun 21, 2004 | 07:30 PM
frederic nelson's Avatar
frederic nelson
I had my muffler removed and replaced with a piece of pipe with the stock tailpipe , it sounds good to me at low rpm's but stand on it . it barks , barks loud .... I guess if I had to do over I wouldn't ... That's just me .... Fred
Old Jun 22, 2004 | 09:41 PM
airtractrdrivr's Avatar
airtractrdrivr
I was getting my trailer unloaded yesterday in San Angelo, TX, and another F350 V10 pulled in to the place I was at. It sounded killer, and I noticed these HUGE exhaust tips hanging out behind the duals. I got to talking to the driver, and he said he was running a Full Boar Performance (almost identical to a Flowmaster 40 series) single in/dual out muffler, and his tips were made from the top 18 inches of a big truck exhaust stack. Tips were about 6 or 7 inches in diameter. Truck had a deep rumble at idle. I left before I got to hear it under a load, but he did rev it up a few times, and it sounded great!. I am now searching for a couple of used chrome Peterbuilt stacks.
Old Jun 23, 2004 | 09:37 AM
chuck641's Avatar
chuck641
i cut mine off right behind the cat. its LOUD but real tinny sounding. it sounds the best at idle. theres definately not a low rumble to it like a v8
Old Jun 23, 2004 | 10:48 AM
airtractrdrivr
Yup, you almost have to put some type of echo tip on it to get any deeper tone to the V10.
Old Jun 23, 2004 | 11:42 AM
bigdmizer's Avatar
bigdmizer
I ran a striaght pipe through the cat, so visible inspection there is a cat but has a straight flow. I put a gibson stainless cat back on it. It sounds good and loud, but definitely not a V-8 sound. But boy when I get on it.................I like it personally! Better throttle response for sure. I love to be in traffic and some guy with a ricer and a loud stereo pull up next to my truck. My exhaust is usually at his window level. I will punch it and give him a blast of V-10 sound right in his window. It's fun!
