Reasonably important question...
Old Jun 15, 2004 | 06:54 PM
nsshull's Avatar
nsshull
Exclamation Reasonably important question...
I've got the 84 Ford F250 with the 460....I'm wondering how much the motor should shake whilst it's in gear but not moving. Just wondering if a lil shake is normal or not. Any replies are welcomed greatly, thank you much
Old Jun 15, 2004 | 10:15 PM
Whiskeyfox's Avatar
Whiskeyfox
a little bit of shaking is normal. my 460 idles around 450-500 when in gear and it shakes about 3/4 of an inch in each direction.
Old Jun 15, 2004 | 10:21 PM
nsshull's Avatar
nsshull
Thanks
Thankee much for the info.
Old Jun 18, 2004 | 09:16 AM
LWJ's Avatar
LWJ
My '86 with a manual trans doesn't really shake. There is a vibration, kind of a little lump-lump at idle but I would not call it a shake.
Larry
Old Jun 18, 2004 | 01:02 PM
jim henderson's Avatar
jim henderson
Yeah most engines will shake side to side a little. The problem comes when it twists in the engine mounts more than a few inches. Then it might be a bad mount, which can cause problems with wiring, plumbing etc if the engine twists in it's cradle.
Good Luck,
Jim Henderson
Old Jun 21, 2004 | 11:33 AM
shawnlee28's Avatar
shawnlee28
My 89 460 runs as smooth as a cadilac.I can balance a nickel on edge on the radiator.Stock and runnin corectly is should be real smooth.Thats the reason ford put these motors in the lincon so it would idle as smooth as a caddy and they do stock. If u have a cam or some other work i have seen em vibrate pretty good.
mdayz28
Nov 12, 2012 09:43 AM
amer28
Apr 29, 2011 10:05 PM
goodwrench
67
Oct 24, 2007 09:42 PM
Skandocious
Apr 11, 2007 09:30 PM
jasonspruill
Aerostar
Nov 6, 2004 02:15 AM
