93 E40d Slipping
Old Jun 15, 2004 | 10:09 AM
Wakeboarder141's Avatar
Wakeboarder141
93 E40d Slipping
Last night when leaving work my transmission started slipping. It would rev up for a second, then lunge forward, rev, lunge, etc. It happenned for about half a mile and then stopped. I checked the fluid and it looks full enough. It doesn't look brown or smell burnt. What would be the best thing to check/fix? Thanks.
Aaron
Old Jun 15, 2004 | 12:02 PM
jim henderson's Avatar
jim henderson
Your tranny is from the years when they had problems. Usually the Torque Converter clutch would slip and then cause other problems related to overheating and debris. Plus I would guess you have a fair number of miles on the tranny by now, unless it was rebuilt, hopefully with upgraded parts.
Without knowing the history of your tranny I would drop the pan and inspect for excess debris. Pepper flakes are usually clutch. I would say there should be no more than a teaspoon. Metal chips larger than say a grain of rice are bad, and more than 1 or two is bad. If the magnet is really fuzzy and has metal flakes, that is also a problem.
I am not an expert on trannies, but if I saw any of the above symptoms and had a lot of miles(over say 80K) I would consider a rebuild. If the fluid was burnt and pink to brown to black then you definitely have a problem.
If everything was OK then maybe some adjustment or sensor is out of spec. I have heard that the gear selector sensor sometimes get out of adjustment and can cause these problems. Hoep one of the experts gives more detail and a correct name for it. Sometimes a fluid change will make the tranny work a lot better, but I would not bet on it if you had lots of miles and any of the other symptoms mentioned above.
Good Luck,
Jim Henderson
Old Jun 19, 2004 | 01:18 PM
fordtruckfan90's Avatar
fordtruckfan90
Im sort of having the same problem, I own a 90 f-150 with e40d, when it would shift gears sometimes would rev up, and recently hauled 800lbs of wood and when i went to leave work today it was chattering(torque converter) and when i went to accelerate it would slip badly, im assuming a rebuild is a must, whats a decent price to pay for a rebuild along with major components that should be replaced, thanks!
crrobinett
Mar 11, 2017 06:20 AM
Phillime
Mar 26, 2016 12:31 PM
littlehillsfarm
Jul 30, 2015 09:01 AM
oatsj
1978 - 1996 Big Bronco
23
May 7, 2010 07:37 PM
true blue
Aug 20, 2006 08:23 PM
