suicides
Old Jun 14, 2004 | 10:01 PM
bc30629's Avatar
bc30629
suicides
I wish to do a suicide on my 1984 f-150. I need to know where to get started and any comments would help greatly. Also , my tie rods need replacing, but im not sure where to go for them. I can get the expensive 100 dollar ones or i found some for 20 at a discount site. Will these be sufficient or should i head down to my local junkyard to find some to fit?
Old Jun 14, 2004 | 10:38 PM
fai4g63's Avatar
fai4g63
I would not put tie rods from the junkyard on my truck. Just go to any auto parts store and they should have them in stock. Just make sure the replacements have grease fittings on them. Moog is a good aftermarket brand
Old Jun 15, 2004 | 12:50 PM
lmadore's Avatar
lmadore
I agree. If you use a used tie rod, your truck may end up in the ditch doing 70 MPH or hit someone else if they fail. You will not have any control. Loose tie rods are grounds for failure of a Motor Vehicle Inspection in those state that still require inspection.
Old Jun 24, 2004 | 01:32 PM
bc30629's Avatar
bc30629
thanks for the info with the tie rods. I have debated and have decided to go new. Sounds like a better choice. I have put myself in a ditch with my old car and do not want that to happen again. But does anyone have any info on suiciding the doors on an older truck. Thanks again
polmonari
Oct 11, 2012 08:58 PM
fast58
Jan 11, 2012 10:49 AM
Suicidal
1997 - 2003 F150
Aug 29, 2008 12:45 PM
eanderson56
17
Jun 9, 2008 01:05 PM
Fire Rooster
21
Jan 30, 2005 09:33 PM
