You ever run yours on a dyno? My last dyno sheet is on my gallery. Lots of witnesses, even one on this Forum.
No I have not ran it on a dyno there are none in my area, there are however a lot of guys running both programmers and I have used thiers to program mine and let me tell you if you are not running the juice you can't keep up with me I have ran them time and time again. I only have one addition that is different than the guy who has the preditor and that is an AFE air sys. I have even taken it out and still beat him. The only other difference is that mine is an early build and his is an 04. I think that that has a lot to do with it. And as you know it has more to do with getting all them ponies to the ground and going than just on a dyno so wheel base and 2 or 4 wheel drive has a lot to do with it.
Hey Enorma, I think you should swap tuners with that guy, (put your edge in his 04 and the preditor in your 03) then run them again, I think that would be a good test and could prove a point one way or the other,
this is the best post on this thread
switching would be very interesting. level the field a bit.
With the 04 being slower, i have heard on this site that some had 70 less foot pounds. But not sure.
I really need to dyno mine i have alway seemed to get the factory freeks for speed when ever i buy a car.
Bob i still have the programmer sitting here waiting to be shipped out tell me more because i really need the shift controle
Mine is a 05-03. I think you are correct and the older ones are faster stock.
The predator replaces the entire flash so if anything it has to be the turbo or???
Hook the Predator up. Install tune. If it is the latest update from Diablesport.com, it will have a bottom Item, factory Tune with improved shifting. Load that one. Try it!
looks like i may not be sending it back. I dont have the latest download though. That i will have to get online. I still wish customer support was better with predator, they could have walked me through it to find out my current version yada yada
I've had some requests filled, like the stock tune with shifting and the PC interface so you can save tunes to the PC and update your own Predator.
Three of my friends have received phone help to update their own tuner so they didn't have to send them back.
It's not hard, go to their download page and read the instructions
I just installed my edge juice with attitude monitor and it's working perfectly. I was surprised....no, shocked how much more power there was even at the lowest setting. so far, it's shifting normally and I couldn't be more pleased. after I get a few more miles on it, I'm gonna go play
