CD player installation advice
Old Jun 13, 2004 | 11:50 PM
droidster's Avatar
droidster
looking for any tips on installing a cd player in my 76 f-150
what did you use to cut the plastic ?
do i need to reinforce the metal after i cut it?
thanx
Old Jun 14, 2004 | 01:07 AM
badbronco78's Avatar
badbronco78
i used a cutting wheel on a dremell tool and it worked great as long as u dont mind a little plastic burning smell. didnt reinforce the metal plate at all and it is still holding solid and my truck dont ride too smooth .
Old Jun 14, 2004 | 01:31 AM
CrazyAirman's Avatar
CrazyAirman
be careful cutting,make sure you use the rear strap, and it will work great!
Old Jun 14, 2004 | 08:45 AM
biggreen78's Avatar
biggreen78
i strapped it down to the top of the ash tray bracketry works good--just make sure it is tight or the bottwm of it will stick out a little
i also didn't bother to reinforce the cut metal bracket
Old Jun 15, 2004 | 01:55 PM
MG86TA's Avatar
MG86TA
Mines all rigged up in there.. to fit in the CD player i had to cut the metal where the ***** were. Since to fit the CD player in i had to cut out the metal from side to side.. to reinforce the sides i cut the heads off of 2 nails and i welded them on the sides. Slips right in and you can't pull it out without keys. Just like stock
Old Jun 15, 2004 | 04:04 PM
droidster's Avatar
droidster
thank you
thanx for the help
i can't wait to hear my new Alpine
Old Jun 15, 2004 | 11:41 PM
jsooke's Avatar
jsooke
I used a mounting kit (well at least part of it) ....
see https://www.ford-trucks.com/forums/s...d.php?t=236001
It has held very well, no rattling or shaking, have been out on the logging roads a few times, no problems.
Jay
